St. Lawrence River
St. Lawrence River
Post by slider38 » Wed Aug 17, 2022 2:17 pm
Hi Folks, I have a new map started - St. Lawrence River. I have been working on the first engine - a Planet. The first Canadian engines were shipped from England. I have tried everything that I can think of to try and get rid of this bluish color to no avail. I finally gave up and just colored the tender to match. Oh well. It works. This is the maps first engine - the Champlain and St Lawrence Planet number 31.
Re: St. Lawrence River
Post by slider38 » Fri Aug 19, 2022 12:42 pm
The longer I looked at that Planet, the less I liked that ugly color, so, I threw it out. Instead, this map will start with the Champlain and St Lawrence 2-2-2 number 12.
The second engine will be the St Lawrence and Atlantic 0-6-0 number 249.
Post by slider38 » Wed Aug 31, 2022 2:20 pm
Another engine comes out of the shop - the Grand Trunk Railway 4-4-0 number 126.
Post by slider38 » Mon Sep 12, 2022 8:06 pm
The latest engine out of the shop is the Grand Trunk 2-6-0 number 714.
Post by slider38 » Wed Sep 21, 2022 8:24 pm
Another engine is ready for the map - the Canadian Pacific Railway 2-8-0 number 22.
Post by slider38 » Fri Sep 23, 2022 3:49 pm
One more engine joins the map's list - the Atlantic, Quebec & Western 4-6-0 number 2268.
Post by slider38 » Fri Sep 30, 2022 2:17 pm
The latest engine out of the shop is the Canadian Pacific 4-6-4 2811.
Post by slider38 » Tue Oct 11, 2022 11:40 pm
The last engine for this map will be the Canadian National 2-8-2 number 3555.
A few more things to build and then I will start transferring things to the actual map and start re-testing. More work ahead.
Post by slider38 » Mon Oct 31, 2022 11:20 pm
I have finally gotten everything transferred to the actual St. Lawrence River map and tested again. Now the real work starts. Time to start testing for game play and get the goals established. Things move a little slower this time of year. I am getting to the golf course as often as the weather permits. As the chill sets in, I expect things will pick up speed. Guess I better get to it.
Post by slider38 » Mon Nov 14, 2022 4:22 pm
I have finished my initial testing. That always leads to a lot of changes - goals adjusted, industries moved and added, etc. etc. I have finished work on the actual map. I am going to give it one more run-through. Assuming that goes well, I just have the event files to build. I am working on it. :D
Dann3
Post by Dann3 » Mon Nov 28, 2022 4:18 pm
Awsome work! Cant wait!
Dan from bobs forum assume its the same slider :D
Dann3
Post by Dann3 » Mon Nov 28, 2022 4:20 pm
Let me know if you need a beta tester!
