Uploading?
- MasteRyder
Uploading?
I don't see anywhere to upload a map to the site. How do I do that?
Thanks...
Thanks...
Re: Uploading?
Remember the screenshot I posted with upload buttons in your discussion of Jancsika's Monarchy map?
If you can't see the upload interface (Upload attachment) at the bottom of the reply screen (you need to scroll down to see it), let me know.
Re: Uploading?
The uplad form will not work if you are uploading large files. This is a restriction just to keep the server from filling up (The more files we have the longer backups take). If you need to upload something ~6-7MB or larger medafire should work: http://www.mediafire.com/
- MasteRyder
Re: Uploading?
Thank you. I was starting to wonder if the file was just too big. I'll try zipping 3 parts to it and see what happens...
- MasteRyder
Re: Uploading?
Okay, four files to be put back together and zipped to use the mapshifter. Hope this upload works... ![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
The files seem to be up there now. Will someone please let me know if all this work was useful? After all, this is simply a modification to Janciskas Monarchy to make it work through to completion.
Thanks for your help guys...
Mike...
Mike...
- Monarchy4.zip
- (5.86 MiB) Downloaded 824 times
- Monarchy3.zip
- (1.53 MiB) Downloaded 861 times
- Monarchy1.zip
- (754.27 KiB) Downloaded 884 times
- Monarchy2.zip
- (6.09 MiB) Downloaded 885 times
Re: Uploading?
You seem to have provided four scenarios versions together. (screenshot)
What exactly is the purpose of that?
![Shocked :shock:](./images/smilies/icon_eek.gif)
Re: Uploading?
Well, I guess since that is the way Jancsika wrote it up 4 years ago, he most likely decided to leave it that way. ![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
You did play it back then...... viewtopic.php?p=38517#p38517
Re: Uploading?
MasteRyder,
your solution works. I though it a pity to lose the historical "Italian Front", however, and I was able to fix the issue. Check out my solution, posted in Janksica's original map thread!
viewtopic.php?p=50760#p50760
![Cool 8)](./images/smilies/icon_cool.gif)
- MasteRyder
Re: Uploading?
Thank you Karsten. A much more elegant fix. This is such a fantastically detailed scenario that I believe that it is his legacy to the game that he loved.
