Revised Map - Arabia
TMILLER
Post by TMILLER » Sun Sep 30, 2012 12:15 pm
Attached is a revised version of the Arabia Map. I have made changes to the map as suggested by Karsten. It now includes a political map of the region that shows up after the second carload of passengers is delivered. I have added the Haramain High Speed Rail project as a Victory Objective and modified the TGV loco so it will haul pilgrims. To play the revised Arabia map, download this file. Unzip it with 7zip and place the Arabia folder in the SMR UserMap folder. You will need to download the old Arabia Parts 2-5 files and place them in the new Arabia folder following the original instructions. If you have already downloaded and unzipped Parts 2-5, just move the Assets2, Assets3, Audio_Files, and Event Files folders to a Temporary folder. Delete the old Arabia folder and replace it with the new one. Then copy the Part 2-5 folders back inside the Arabia file. Hope to hear from someone and good luck on your trip to Arabia. - TMiller
Arabia.7z
Download file, unzip with 7zip, and place Arabia file in empty SMR UserMaps folder. Then download original Arabia Parts 2,3,4 and 5. and insert the unzipped folders inside the Arabia folder.
(6 MiB) Downloaded 798 times
