Can you disable the arrival sounds
Gupster
Post by Gupster » Fri May 22, 2009 2:37 am
Hi. Is there a way to disable the money clincking train arrival sound. It drives me crazy and is constant once you have enough trains. I don't want to turn down the volume of the other sound effects.
Re: Can you disable the arrival sounds
Post by Rodea2007 » Fri May 22, 2009 9:03 am
Gupster wrote:Hi. Is there a way to disable the money clincking train arrival sound. It drives me crazy and is constant once you have enough trains. I don't want to turn down the volume of the other sound effects.
Try this step....Ingame click Game Menu then click option then select interface sound and move slider to minimal, money clincking train arrival sound will be mute
RockyNarrowGauge
Post by RockyNarrowGauge » Fri May 22, 2009 3:13 pm
This was rather rather simple for me. A bit of searching and trial and error. It's in the Audio2DScripts.xml file. Go into C:\Documents and Settings\(computer name)\My Documents\My Games\Sid Meier's Railroads!\CustomAssets and make a folder called XML. In that one make a folder called Audio. If you already have them there, great!
Now unzip the attached file and place it in the Audio folder.
Now you are doing electronic transactions! No coins to tinkle!
Not to worry, I just changed the AS2D_CASH volume Max and Min from 35 to 3.
Hope you like it.
Audio2DScripts.zip
(1.15 KiB) Downloaded 473 times
