Inauguration Special SAM map
Post by Jancsika » Sun Jan 25, 2009 8:28 pm
This is 14 x 14 SAM (Stand Alone Map) of the USA
The action is that everybody is going to the Inauguration.
“Betty Boop” ( If you don't know who Betty Boop is, Google it!) was elected.
There are Seven different groups of people, that are going to Washington:
1.Voters from all over the country.
2.Senators from three different Statehouse.
3.Celebrities from Los Angeles
4.Patriots from Denver
5.Stockbrokers from New York.
6.Hippies from San Francisco.
7.CarMakers from Detroit via Vegas.
Since all trails converge to Washington it is a rather difficult map to play. You have 5 years to complete the mission. It can be done!
The map seems to be stable. There were no CTD-s for me.
How to install and use SAM (Stand Alone Maps)
1) Go into C:\Documents and Settings\(your computers name)\My Documents\My Games and rename the Sid Meier's Railroads! folder you presently have, adding an ending to it, whatever you want. ("SidMeier's Railroads - Old" will do just fine)
2) Start the game. When it gets to the main menu, exit. This will create a brand new, empty Sid Meier's Railroads! folder.
3) Go into the Sid Meier's Railroads! folder you renamed and copy the 'Settings.ini' file into the newly created Sid Meier's Railroads! folder. You now have the basis for all future SAM and CIC maps.This is not mandatory, but your old "Settings.ini" file has all the customisation that you made to the game. (Clouds, graphics setting, Newspaper etc.)
4) Open the Sid Meier's Railroads! folder, then open the UserMaps folder.
5) Close all folders and play the map
Just unzip the file In the C:\My Documents\.....\SidMeier's Railroads!\UserMaps folder and enjoy.
Inauguration V_3_0_Final.zip
This is the final version!!
(12.78 MiB) Downloaded 523 times
New Icons.jpg (21.84 KiB) Viewed 13960 times
Kroguys
Re: Inauguration Special SAM map
Post by Kroguys » Sun Jan 25, 2009 9:11 pm
I have not played this map. But it sounds like a ton of fun! :lol:
AKA: CrashDummy__1.1
Moschops
Post by Moschops » Mon Jan 26, 2009 7:31 pm
hey!
Love all the new maps. Having trouble getting this one going. CTD at start... moved custom assets into clean SMR and it runs fine, can't ship any of the custom goods. It won't let me add the cars to the route. help
thx :)
Moschops
Post by Moschops » Mon Jan 26, 2009 9:52 pm
heh... never mind. I put the fpk files in custom assets and it ran perfectly. Also figured out I had to use the pass engines to transport :P. Great map lots of fun
thx :)
Post by Jancsika » Mon Jan 26, 2009 9:58 pm
I have to apologize. I was using 7Zip compression utility, and it has dropped some of the files.
I also have the whole program on my FTP site
http://home.comcast.net/~janosballa/Ina ... 0V_1_1.zip
You can download it from there in one file.
The engines supposed to haul freight too. Please check the new upload.
Sorry The FTP link is broken!!!!?
Pete
Post by Pete » Tue Jan 27, 2009 4:05 pm
The link to the one file "Cannot be found"
Are the other 2 now good for downloading?
Pete
Pete
Post by Pete » Tue Jan 27, 2009 4:17 pm
Jancsika wrote:I have to apologize. I was using 7Zip compression utility, and it has dropped some of the files.
Never mind.
The link on Bobby's site worked.
Pete
Post by Jancsika » Tue Jan 27, 2009 6:46 pm
Yes it happened to me too. One of the files took two tries to get it right. Chek the file size when downloading.
It happened before. First I blamed on the ZIP program I use, but now I am not quite sure.....
Bobby's link:http://eric.bkbobby.com/
Hawk's link:http://hawkdawg.com/
They are bothh good and solid.
Pete
Post by Pete » Tue Jan 27, 2009 7:40 pm
Wow!
Great job........Really shows what can be done with these things. Played for 2 hours without a hitch.
1 suggestion if I may.
The 2 large diesels are basically unused. They only haul mail. Would it be possible to use them for at least all the people going to Washington? Preferablly open to all cargos.
Regardless, this is one I'll be playing a lot.
Thanks a ton
Pete
Post by Jancsika » Tue Jan 27, 2009 8:13 pm
The engines ment to haul freight too. I had a lot of trouble with uploasd. Since than I have changed my ZIP program.
Here Is the Trains_Inauguration.XML file. Just replace the one you have it should work
<RRTTrains>
<szName>TAG_NAME_F_SERIES</szName>
</Train>
<szName>TAG_NAME_MIKADO</szName>
</Train>
<szName>TAG_NAME_AMERICAN</szName>
</Train>
<szName>TAG_NAME_GP_SERIES</szName>
</Train>
<szName>TAG_NAME_AC4400_WB</szName>
<Year>1994</Year>
<szManufacturerName>GE</szManufacturerName>
<szModel>AC4400warbonnet_santafe.kfm</szModel>
<szDummyModel>AC4400_dummies.nif</szDummyModel>
<szCar>_v2</szCar>
<szNewTrainImage>event_newtrain_ac4400.dds</szNewTrainImage>
<MaxSpeed>14</MaxSpeed>
<Speed0>15</Speed0>
<Power>30</Power>
<Cost>350000</Cost>
<MaintenanceCost>4000</MaintenanceCost>
<Diesel>1</Diesel>
<RunLength>80</RunLength>
<HasEngineer>0</HasEngineer>
<rgbDefaultColor>65,139,255</rgbDefaultColor>
<BitmapIcon>
<szFile>routing_44SantaWar.tga</szFile>
</BitmapIcon>
<szStartSound>AS3D_TR_DIESEL_ENGINE_START_3</szStartSound>
<szStopSound>AS3D_TR_DIESEL_ENGINE_STOP_3</szStopSound>
<iPitchChange>2000</iPitchChange>
<SpeedSounds>
<szSpeed>AS3D_TR_DIESEL_ENGINE_SLOW_LP_3</szSpeed>
<szSpeed>AS3D_TR_DIESEL_ENGINE_MID_SLOW_LP_3</szSpeed>
<szSpeed>AS3D_TR_DIESEL_ENGINE_MID_FAST_LP_3</szSpeed>
<szSpeed>AS3D_TR_DIESEL_ENGINE_FAST_LP_3</szSpeed>
</SpeedSounds>
</Train>
<szName>TAG_NAME_SP_8110_C44-9W</szName>
<Year>1994</Year>
<szModel>SP_8110_C44-9W.kfm</szModel>
<szDummyModel>SP_8110_C44-9W_Dummies.nif</szDummyModel>
<szCar>_v2</szCar>
<szNewTrainImage>event_newtrain_SP_8110_C44-9W.dds</szNewTrainImage>
<MaxSpeed>12</MaxSpeed>
<Speed0>15</Speed0>
<Power>18</Power>
<Cost>300000</Cost>
<Diesel>1</Diesel>
<BitmapIcon>
<szFile>routing_SP_8110_C44-9W.tga</szFile>
</BitmapIcon>
<SpeedSounds>
</SpeedSounds>
<szSharpAngleSquea>AS3D_CURVE_SQUEAL</szSharpAngleSquea>
<szAverageAngleSquea>AS3D_CURVE_SQUEAL_MEDIUM</szAverageAngleSquea>
<szSlightAngleSquea>AS3D_CURVE_SQUEAL_LIGHT</szSlightAngleSquea>
</Train>
</RRTTrains>
Here is a screen shot I just took:
Pete
Post by Pete » Tue Jan 27, 2009 9:42 pm
H there
I just copied and pasted and saved the file.
No difference. Won't pick up anything but mail.
Which is the most up to date zip. I'll redownload it.
I've been working with all 3 of yours.
Pete
Post by Jancsika » Wed Jan 28, 2009 2:11 am
Pete! I am uploading complete new ZIP-s. Will be marked "A" and '' B". ( I was getting confused with the numbers myself, so I deleted the whole thing (ZIPS) and start from scratch.
mutantz
Post by mutantz » Wed Jan 28, 2009 4:26 am
i do not see an icon for arms,it shows when you mouse over a city,but click on the city and there is a blank space that will say arms with you mouse over the 4 demand icons.
Pentium 4 3.4 Mhz
4096 ddr-2 Memory
Ati Radeon 1650 512 mgs ram
Lg 226w 23" 1680 x 1050
120 gig SATA HD/250 gig SATA HD
Memorex dvd 52x/32x/52x
Post by Jancsika » Wed Jan 28, 2009 4:09 pm
Try to reinstall the game. I just doublechecked myself, downloaded and installed a completely new game, and the Rifle (Arms) icons were there.
But what i've noticed, that it took 3 tries to dowload the right size of ZIP file.
There has been download problems before with larger files. So the best thing is always to check if the complete file was dowloaded.
Pete
Post by Pete » Wed Jan 28, 2009 5:47 pm
Ok. Here's my test.
Downloaded A and B from "Hooked" forum.
First time A came at 306K.
Re-downloaded both.
A-7014KB........Unzipped 45,581
B-7520KB........Unzipped 21996
Downloaded both from "Bobby's Forum.
B-7520KB.........Unzipped 21996
Is it strange that B is the larger zipped, yet unzipped it's smaller.
Loaded the game and STILL; the 2 larger diesels will not haul freight.
Pete
