i as you can see in this topic i am looking for a expert or someone that knows the coding really well like as in...hmm just someone that knows how to make maps Manually and stuff. I guess it is going to be a hard search but i need this because i am a quick learner to coding and i am better at coding then mapping. so i was wonding if i code have key words list like for example this would be in the list of Required
<RRT_Trains>
<RRT_Goods>
and stuff like that
Thats all
it might be easier for me to just make the files manually
or harder never know
Looking for an expert at the modding files on SMR
Re: Looking for an expert at the modding files on SMR
The best way to learn is to take a map and read all the files through. Then try to make your own looking at sample maps files.
Lowell wrote:The best way to learn is to take a map and read all the files through. Then try to make your own looking at sample maps files.
ok that sounds like a great idea
If you want to learn, i suggest that you read some of the posts on this subject
And if you get stuck just ask. There always will be somebody glad to help.
It is not that difficult, you will not need any special programing knowledge, only to be able to edit text files and some common sense.
