Post
by Rodea2007 » Tue Apr 01, 2008 9:57 am
I have been uploaded The Last Update From West Sumatera Map at address
http://rapidshare.com/files/103992197/S ... o.exe.html
EDIT//...OR.
http://model-railroading.net/SMRfiles/S ... enario.exe
This addres from DR. Frag
Thank's DF for it
The Last Update this Map provided adding new Industry Offshore Oilrig
This Installer support Multilanguages, it does mean you can run this Installer with what language you used
All error in Map before this has been repaired, but if you get error don't hesitate to post what your problem
I was tried to Install this map at anothers computer, until nows that work's fine. I hope so you can success install and play's this map without error.
Good lucky....
- GP38
- SMRailroads!0003.jpg (197.88 KiB) Viewed 16265 times
- EMD F3
- SMRailroads!0005.jpg (241.2 KiB) Viewed 16273 times
- Offshore Oilrig
- SMRailroads!0002.jpg (182.23 KiB) Viewed 16277 times
Rodea2007 on Thu Apr 03, 2008 6:08 am, edited 1 time in total.
Borkvald
Post
by Borkvald » Tue Apr 01, 2008 11:12 am
Installed the map, this quote is from det readme file you get access to after innstalling the map:
"To succesfull Install this map please delete all old FPK from West Sumatera Map and old Folder West Sumatera Map in UserMaps after that click this Installer to Install West Sumatera Map Revision 1.0"
Well, a bit to late.
When that mark made, to the map....
Post
by karsten » Tue Apr 01, 2008 11:49 am
Install worked perfectly this time. Neat. Too bad I will be travelling the next two weeks, so I won't be able to play until then.
I notice there is still a small problem with the graphics shader, also when I zoom up close to my Canberra building. So some little compatibility element must still be missing.
Great work!
Post
by Lowell » Tue Apr 01, 2008 7:56 pm
It loaded fine inside SMRI... but crashed in a clean game load. So the maps files still needs something from the smri items for it to run by itself.
It looks great, I like the Cargo Ship, and the animation at the dock. I saw you tried to use the red light from the hospital on the Lighthouse, but it wasn't spinning around.
Nice job, thanks...
Amat baik bekerja Rodea, aku mungkin bagaikan ke memakai mu muatan kapal atas ku peta, apabila nya adalah baiklah dengan anda. Melihat...aku bisa berbicara mu bahasa, namun aku mempunyai ke memakai sebatang alih bahasa. Sekarang kami bisa bericara dan tidak ada yang ahan kenal alangkah dalam kami adalah berbicara ke mana-mana.
Aku bermain melalui permainan dan segala berlari besar. Aku cinta peta...amat bagus permainan.
Post
by Rodea2007 » Wed Apr 02, 2008 2:07 am
Borkvald wrote:Installed the map, this quote is from det readme file you get access to after innstalling the map:
To late for you Borkvald, not to the peoples wich got CTD when playing my Map...
But I suggest for you to install the latest Map because have adding new Industry Offshore Oilrig
Post
by Rodea2007 » Wed Apr 02, 2008 3:12 am
Lowell wrote:It loaded fine inside SMRI... but crashed in a clean game load. So the maps files still needs something from the smri items for it to run by itself.
Nice job, thanks...
Thank's for your comment in Indonesian Language, but you must more learning to correct used because english language and indonesia language having different structur for example your map in english if talk in Indonesia language not kamu peta but peta kamu, object is behind subject not in front of subject
this is different make me to difficult to translate Indonesian to english
BTW...everything's model on my Map free to used by all peoples in this forum into RRT game them, don't worry about Issu Right...
Thank's
Post
by Lowell » Wed Apr 02, 2008 4:03 am
Oh...I forgot the object is behind the subject. What is strange is there are no past tence words, no word "the" and a couple other words I use often. Then...on many words there are three or four spellings. I learned the numbers easy enough.
Post
by Rodea2007 » Wed Apr 02, 2008 5:16 am
Lowell wrote:Oh...I forgot the object is behind the subject. What is strange is there are no past tence words, no word "the" and a couple other words I use often. Then...on many words there are three or four spellings. I learned the numbers easy enough.
Yes for you is Strange...Indonesian Language have not past tense, ferfect tense, future tense ect, it means indonesia language just simple to learn
Post
by Rodea2007 » Wed Apr 02, 2008 5:24 am
Nice job, thanks...
This corrected in Indonesian Language
kerja yang Bagus Rodea(Goods works Rodea), aku mungkin akan memakai Kapal muatan buatan kamu(your cargo ship) kedalam peta ku apabila anda/kamu berkenan. Lihat aku bisa berbicara memakai bahasa kamu, namun aku harus memakai kamus(dictionary), sekarang kami bisa berbicara apa saja...just simple...
Post
by Jancsika » Thu Apr 10, 2008 2:35 am
Great map. Lots of new graphics. No problems loading or playing. I have 22 trains and 4500 miles of rails and its running smooth. I love the Mikado engines!
- Mikado special loading at the Oil Refinery.
Post
by Rodea2007 » Thu Apr 10, 2008 3:38 am
Jancsika wrote:Great map. Lots of new graphics. No problems loading or playing. I have 22 trains and 4500 miles of rails and its running smooth. I love the Mikado engines!
Thanks for your comment...Jancsika
Post
by karsten » Fri Apr 11, 2008 6:08 am
Has anyone achieved the "three villages to metropolis" condition? Does not seem to work for me, am I missing something?
Post
by Rodea2007 » Fri Apr 11, 2008 6:32 am
karsten wrote:Has anyone achieved the "three villages to metropolis" condition? Does not seem to work for me, am I missing something?
I've been playing : Robert Baron, Hard, 3 AI's and only until 1940 I was Bought out all AI's and finish all goals at 1950...
What happen to you Karsten...
