I am using Corel's Paint Shop Pro. When I erase the background like for clear areas around the wheels...I get white edges. I even tried zooming way in to get the edges close. Anyone know where I can change that to black or get it to where you can't see a seam? If you look close at the wheels you see some of it. You see it a tad more in-game when close-up.
In this picture I also need to remove the players colors as the blue is showing through the southern red hood making it purple. Seems I saw that in the train skinning kit.
These white seams bother me, the games models don't have white seams.
EDIT//I guess a second question would be is there an easy way to remove the player colors.
Editing train engines
- SOU005.png (2.07 MiB) Viewed 4990 times
Well, found that Corel stinks for getting the transparencies done. Gimp works well enough...thanks for the idea, haden't thought of it.
I found how to take off/on the player colors...maybe later I look at the 4400 dummy unit and get the player colors to pop up on it.
The red came out a tad too bright and needs toned down/darkened a tad, but here is the start of the Southern engines...tender is next.
- SOU008.png (1.42 MiB) Viewed 4951 times
- GeneralIndustries
how
how do you edit a locomotive's speed
