looking for passenger cars & a couple of ?'s
Thanks for pointing me to basin and range. There is a lot of great content there. Now I just have to figure out how to use it on other maps as well. It seems to work in traintable mode but of any other level the engines don't seem to show up. Also I'm wonding how to incorporate that port / can carrier in other maps. Lastly are there any other passenger cars out there. I found a santa fe but I am also looking for some of the other older ones burlington etc... Thanks for any help..
- K-class
Hello etime and welcome
Trains appear in a date order in the B and R the first train is at 1926 so you may not be at the date yet???
Open up RRT_Trains_BasinAndRange.xml and have a look at <Year>1970</Year> This is the year the train appears.
B & R also uses it own Tender Cars and most of the maps use the global xml file so Manges tender mod works - meaning you may have to add tender cars into your RRT_TrainCars_ map xml
Cut a long story short this is already posted and have a read of these two posts which has it all covered.
see Railroads! Strategy - Modifying files to add dual engines
http://www.hookedgamers.com/forums/viewtopic.php?t=1568
You'll need to open the forum to page 7 of Arizona Gold V2.2 under Railroads! Mods - Maps
http://www.hookedgamers.com/forums/view ... c&start=90
