Requested UK map
jowe10
Requested UK map
Post by jowe10 » Sat Aug 18, 2007 3:06 am
Here is a map of the lower UK as requested by omrail in the "UKLargeMP map" post.
omrail - download and modify as you wish. I hope this is a good start to what you were looking for.
UK_lower.rar
15 x 15 map using standard objects
(265.39 KiB) Downloaded 518 times
omrail
Made Newer Version
Post by omrail » Sat Aug 18, 2007 9:47 am
thanks for making the map jowe10. just downloaded it.
EDIT ( Jan 08 )
This map is very good
iv'e played it a couple of times on multiplayer.
recently i've added some new towns & cities to the map But i couldn't add the Tamar & Tavy & Plym Rivers so its less real. I Also put some more hills on Dartmoor.
Devon.rar
Compressed: 300kb
Uncompressed: 19mb
(267.34 KiB) Downloaded 527 times
jowe10
Post by jowe10 » Sun Feb 17, 2008 3:03 pm
Omrail: Not sure why you are saying you can't add the rivers. If you go into the terrain editor just like you did to add hills, you can add the rivers by lowering the land elevation until you see water. use the right mouse button to lower the land elevation instead of the left mouse button you used to raise it.
I also noticed you have trees out in the water. To delete those, just use the right mouse button when you are editing trees to delete.
Post by snoopy55 » Sun Feb 17, 2008 5:31 pm
If adding the rivers makes deep canyons, just make a small dip in the landscape and paint it blue. If you keep it deep enough, the bridges will do Ok. Course, I've seen rivers made the other way that were damed by the railroads, but they can do that if they choose.....
omrail
Post by omrail » Tue Mar 18, 2008 4:45 pm
thanks for the help.
