yanki54
Post
by yanki54 » Mon Jun 04, 2007 9:56 pm
hey dudes!
i have a ridiculous problem im glad to happy if u help me
i start with one city for ex baltimore. i cannect it to another city for ex LA. i put a train tarin goes to LA then turns back but never reaches thebaltimore stationagain. why is that? it stops in front of the stationbut cannot reach it?
good day guys
edit: i found a new problem in my game. my second freight cargo cannot be loaded. i wait forever but nothing changes. i loved railroad tycoon but this game is always a problem
Post
by Warll » Mon Jun 04, 2007 11:43 pm
Upload a save and tell us your specs.
Post
by Dr Frag » Tue Jun 05, 2007 5:26 am
Sounds like the same problem posted in Technical Issues;
Trains don't run at all. ou guys should compare systems.
yanki54
Post
by yanki54 » Tue Jun 05, 2007 8:58 am
core 2 duo 1.66 ghz
1 gb ddr2 ram
geforce 7400 256 mb turbo cache graphic card
arent they enough to play?
i can play game no problem i thnk
yanki54 on Tue Jun 05, 2007 9:29 am, edited 1 time in total.
yanki54
Post
by yanki54 » Tue Jun 05, 2007 9:14 am
this is a savedgame
- ss.rar
- (1.13 MiB) Downloaded 390 times
yanki54
Post
by yanki54 » Tue Jun 05, 2007 4:53 pm
hey guys i think i made it. i found a way to recover it. i changed the graphics to 1280X800 and it worked.
but , did not understand that why it doesnot work for another resolution
thanx for ur helps
im still working on it. if i find same problem i gonna post u again
Post
by Warll » Tue Jun 05, 2007 4:57 pm
Interesting, I never thought that res settings could affect game play.
Post
by Lowell » Tue Jun 05, 2007 8:59 pm
Mine are set as 1400 x 1050, 8x anti-aliasing, Trees= High, Shadows= Off, Shader=High...you may want medium, Textures=High. I'm using an EVGA (Nvidia) 680i SLI motherboard with an EVGA (Nvidia) 8800, I run the motherboard and system ram (4gig ddr2 d/c) at 800mhz. Its running xp but have the vista upgrade...I'm backing everything up right now getting ready. Believe it or not the "Northbridge chipset" is very important...I've had real good luck so far with their motherboard...Nvidia is the way to go for now. You will need to increase your page/swap file size...the game and windows won't run without it. Anouther trick is to use the new style hard drives...you need the newer style motherboards for this trick though...
Get the hard drive that is S-ATA/7200rpm/16M/"and transmits data at" 3.0 Gbps.
That can run windows data and the games and more back and forth with no problem. Vista will run better on these drives than the older snail pace drives...as I have built a couple new pcs with vista already...just not my workstation yet.
Post
by dwax » Wed Jun 06, 2007 2:44 am
Worked for me, I added a different engine.
- ss.JPG (194.28 KiB) Viewed 10863 times
yanki54
Post
by yanki54 » Wed Jun 06, 2007 10:29 am
hey guys, i think i have toapologise to all u. because i think the problem is not resolution, but anti alising configuration. i changed resoloution again and it worke but when i changed the anti-alising to zero(default) i happaned again. im playing now with 4X and no problem. it works
warll i think u are right, res dont affect game play in such a way
Zorander
Post
by Zorander » Wed Jun 06, 2007 9:20 pm
So what exactly is anti-aliasing?
