tomasvicente38
Post
by tomasvicente38 » Thu May 31, 2007 12:02 pm
To install in custom assets and to stick the folder of the news of Valencia in custom assets.
- Valencia.zip
- Valencia
- (983.32 KiB) Downloaded 541 times
tomasvicente38
Post
by tomasvicente38 » Thu May 31, 2007 7:32 pm
The installation is just as the map of Utah, you must create a folder with the name of Valencia and stick all news.
Post
by atani » Thu May 31, 2007 10:43 pm
tomasvicente38 wrote:The installation is just as the map of Utah, you must create a folder with the name of Valencia and stick all news.
Automated installer will be posted soon for this map.
Post
by snoopy55 » Fri Jun 01, 2007 2:08 am
Atani - you might want to change the name and XML files in some way as he has already published a map by this name.
Post
by atani » Fri Jun 01, 2007 2:41 am
snoopy55 wrote:Atani - you might want to change the name and XML files in some way as he has already published a map by this name.
Good idea. I will handle this in the installer to name it accordingly. I have not looked at the files yet but do they need translating?
If so, how different from the other Valencia map are these?
tomasvicente38
Post
by tomasvicente38 » Fri Jun 01, 2007 7:21 am
The other version settled in user maps. The new version settles in custom assets. They are two different forms to see the map.
tomasvicente38
Post
by tomasvicente38 » Fri Jun 01, 2007 7:24 am
I would give the possibility of playing the map in anyone of the two versions and that each one chooses the one that more it likes.
Post
by atani » Fri Jun 01, 2007 4:02 pm
tomasvicente38 wrote:I would give the possibility of playing the map in anyone of the two versions and that each one chooses the one that more it likes.
Based on this, I will rename this map to be uniquely named (simple character added to the name) so-as all users can choose between the two maps (Valencia and say ValenciaC) and installers will be produced for both separately.
