RE: Rail Sizing
- HisAlterEgo
RE: Rail Sizing
I made another thread in the Misc catagory but no responses about changing the size of the track to better match Mange's tender mods new size cars. I checked in the install directory for SMR and found a tracks folder under custom assests I think, but some of them are.nif files. What program would I use to open a .nif file? I just want to change the scale of the track if possible.
Intel P4 3.4 Ghz
2 GB DDR2 PC2 4200 SDRAM 533 Mhz
256 MB GeForce 6800 GTO
XP Home
XP Home
- K-class
Others have been using nifskope
http://sourceforge.net/project/showfile ... _id=170735
see
http://www.hookedforums.com/forwarder.h ... php?t=1374
http://www.hookedgamers.com/forums/view ... 4807#14807
I read your other post and I cant see the difference
If you look in RRT_Trains.xml and RRT_TrainCars.xml gloabl files there is
<RRTTrainCars>
<Scale>0.8</Scale>
I don't know what it does as I changed it and didn't really see the difference.
Someone will post or help shortly I'm sure.
see
<RRTTrainCars>
<Scale>0.8</Scale>
- HisAlterEgo
K,
from what i understand that .8 for size scale makes the rolling stock and engines slightly smaller. if you zoom in on a car rolling on the tracks that has been changed to .8, you can see the wheels are just inside the tracks and don't quite match up. if you change the value back to 1 as originally shipped, the cars are slightly bigger and their wheels match up perfectly with the rails. That's what Mange's tender mod did. I like the smaller car scale now i just want to make the tracks a hair smaller to match the smaller cars/wheels.
Intel P4 3.4 Ghz
XP Home
XP Home
- stormfather
I prefer the smaller scale too, I set the locos to 0.8 for my America Map in the RRT_Trains_America file. With the exception of the earliest locos (Grasshopper, Norris, etc.) they look much better with the cars, especially passenger cars. I'm sure that the rails can be resized, the files can be found in the assets/track directory. I don't know how to edit models, however.
On a related topic, I tried to stop the game from building those smooth sections of track under stations and annexes by copying the .kfm for standard track (found in assets/track) and renaming it to replace the .flm found for the station track (found in one of the two 'update' .fpks) It didn't work. It didn't crash the game or anything, but it didn't make any difference, and I lost interest before I could look into it any further.
- GS-Railroad
I would love to get rid of those station tracks. If you save and reload your game it will update them but they just don't look right unless they are going to conform to a proper standard of usage. I would love to see them gone at this point or a toggle.
Smaller scale track to match Tender scale engines and cars would be interesting. Removed station platform specific track graphics would be nice. Shortened station platform track length would help with cities that are very close togeather.
Intel Core2 6600 @ 2.70 GHz
EVGA Nvidia NForce 680i @ 1200MHz
EVGA 8800 GTX @ 576MHz w/768MB 384bit DDR3 @ 900MHz
Corsair Dominator 1GB 4-4-4 12 DDR2 @ 800MHz x2
Sound Blaster Fatality 64MB
150GB Raptor
Dell 2407 WFP Display
XBOX 360 - Live
150GB Raptor
XBOX 360 - Live
If you want to change the depot track I think you have to remove the track_depot.nif file in the Update_1_1_0_00.FPK file.
What I did was open Update_1_1_0_00.FPK in DragonUnpacker, create a folder for it's contents (I used <install dir>\Assets\Update_1_1_0_00, unpack the contents of the FPK into this folder and MOVE the Update_1_1_0_00.FPK to another folder outside of SMRs reach (like your desktop)
Now go into the folder you created and DELETE the following files:
track_depot.nif
track_diff_02.dds
track_norm_02.dds
track_spec_02.dds
This will get rid of the special concrete depot track.
Next go into <install dir>\Assets\Track and make a COPY of track.nif and RENAME the copy to track_depot.nif.
Now you have Depot track that looks like all the rest of the track.
I don't really recommend it since it will make identifying Depot track difficult but I also don't like the way SMR hacks up the Depot track so I understand the desire.
track_depot.nif
track_diff_02.dds
track_norm_02.dds
track_spec_02.dds
Okay, it turns out that it's rather easy to change the track size. In the .nif files there is a setting for Scale in the Scene Root block. Normally it's set to 1.0000 but here I have set mine to 0.9000.
The only drawback is that it scales in all directions and not just width.
- Regular rails at 0.9 & Depot rails at 1.0
- TrackScale.jpg (181.81 KiB) Viewed 8239 times
- GS-Railroad
