Rusia
tomasvicente38
Rusia
Post by tomasvicente38 » Sat Mar 10, 2007 10:49 pm
Map of Russia.
Rusia_SAM.zip
(4.82 MiB) Downloaded 611 times
Setup_Rusia_1[1].0b.zip
(362.01 KiB) Downloaded 628 times
Rusia.zip
Transiberian railroad.
(494.46 KiB) Downloaded 748 times
Transiberian map.
Transiberian map.
Last edited by tomasvicente38 on Sun Mar 11, 2007 8:51 pm, edited 1 time in total.
Post by atani » Sun Mar 11, 2007 8:30 am
Installer containing the original spanish text and an english translation attached.
2007-03-11
Updated to cleanup unused goods and cars, added Beer Cask Car to resolve beer deliveries.
2007-04-13
Updated to fix typo in TrainCars xml file.
Setup_Rusia_1.0b.zip
(362.01 KiB) Downloaded 1374 times
Post by snoopy55 » Sun Mar 11, 2007 9:50 am
tomasvicente38 - Espero usted no tome esto incorrecto, usted está haciendo grandes mapas, pero hay algunas cosas que aparece que usted es inconsciente de. Escribí esto para los creaters nuevos del mapa, así que calculé que una traducción pudo ayudarle. Basicly si usted deja mercancías que usted no desea utilizar en el RRT_Goods XML, demuestran para arriba en el mapa. Espero que esto ayude.
(I hope you don't take this wrong, you are making great maps, but there are a few things that it appears you are unaware of. I wrote this for new map creaters, so I figured a translation might help you. Basicly if you leave Goods you don't want to use in the RRT_Goods XML, they show up in the Map. I hope this helps.)
Stripped Masters.zip
(14.39 KiB) Downloaded 435 times
tomasvicente38
Post by tomasvicente38 » Sun Mar 11, 2007 1:55 pm
There is a series of products that the city demanded when have grown to metropolis, large city and conglomerate
Post by snoopy55 » Sun Mar 11, 2007 3:16 pm
tomasvicente38 - in RRT_Industries you have Cornfields and Vineyard, but neither placed. Under RRT_Goods you have Cornmeal, Grapes, Swine and Wine, which will show under Goods, but not on the map. Under RRT_TrainCars you are missing Beer Cask Car which will cause a crach when you try to ship Beer.
yep
Post by Slappy Da Clown » Sun Mar 11, 2007 4:42 pm
Played gr8 until I demanded Beer. I crashed it several times to make sure. As soon as you pick up beer it crashes.
The scenario is gr8 except Vladisvolstok demands 4 different goods, but you can only own 3 industries in one city. One of the 4 goods should be something its already asking for or cut it to 3 goods.
Slappy
Post by atani » Sun Mar 11, 2007 6:00 pm
snoopy55 wrote:tomasvicente38 - in RRT_Industries you have Cornfields and Vineyard, but neither placed. Under RRT_Goods you have Cornmeal, Grapes, Swine and Wine, which will show under Goods, but not on the map. Under RRT_TrainCars you are missing Beer Cask Car which will cause a crach when you try to ship Beer.
I am thinking of writing a map optimizer which would clean up these sort of things. I will see what I can come up with..
I am going to repost the installer here after fixing the Beer Cask Car entry.
Re: yep
Post by atani » Sun Mar 11, 2007 6:12 pm
Slappy Da Clown wrote:The scenario is gr8 except Vladisvolstok demands 4 different goods, but you can only own 3 industries in one city. One of the 4 goods should be something its already asking for or cut it to 3 goods.
I looked at the RRT_Cities_Rusia.xml file, the way to reach this goal is to create an industry for Oil, Steel and Wood resources. Arms will automatically be demanded by Vladisvolstok once it reaches the "Conglomerate" level (two levels higher than metropolis).
I do agree though, that this is a very hard goal to achieve. I would suggest start on it rather early in the scenario so you can grow it early enough to get it to the right level to complete this goal.
Post by snoopy55 » Sun Mar 11, 2007 6:12 pm
It would have to ask questions, I looked at tomas' Sudamerica map and it has Dairy Farm and Milk, but it goes now where after that. Remove those 2 or add the Industry? I have an oooolllllldddd dBase5 which uses databases and you write a program, then it converts it to a stand-alone, but it's been 20 years since I did programing in that. The old brain cells don't work like they should :?
tomasvicente38
Post by tomasvicente38 » Sun Mar 11, 2007 8:45 pm
Thanks to Snoopy I have corrected the map and it already works correctly. I did not perceive myself of the failure, because it had not sent beer. Thanks.
I have corrected the map and it I have returned to hang.
Pete
Post by Pete » Sun Mar 11, 2007 9:04 pm
Atani
Installed your Russia with the installer.
Still crashing when trying to pick up beer.
Going to install Thomas edited map and give it a try.
Pete
Mikhail@RU
Post by Mikhail@RU » Sun Mar 11, 2007 10:21 pm
First of all, thanks a lot. Good map, but need a bit of work. Some notices: 1)why there are SO much snow??? Siberian summer is really hot :) smth about 25-35 C. 2)Where is the mountains, hills and taiga in Russia, Ural mountains for example? 3)At least one city have soviet name (Novosibirsk was renamed in 1925 from Novonikolaevsk, for Nikolay II honour). Last thing more just for historical info.
tomasvicente38
Post by tomasvicente38 » Sun Mar 11, 2007 10:34 pm
I have published the map, I have cleared the wine, the pigs, the vineyard and have fixed the one of the beer, the map no longer falls.
I am going to try to translate it to the English with a translator.
Pete
Post by Pete » Sun Mar 11, 2007 11:00 pm
Tomas
Installed your edited map and it works great. The beer flows in Siberia.
Thanks for a super map.
Pete
tomasvicente38
Post by tomasvicente38 » Sun Mar 11, 2007 11:18 pm
Map of Russia in English.
Rusia English.zip
Map of Russia
(494.34 KiB) Downloaded 562 times
