Spain
OK,
here you can download the other version:
I Changed the brightness (-75%) of the orignal posted map of spain (by tomasvicente38).
This map is not fine-tuned, i could add some more mountains and flatten out maybe more etc...
But you can see the effect by adapting the brightness
(i also very quickly flatten the height at the fisherie)
(very quickly done, not tested)
have fun, and thanx go to tomasvicente38
- Spain (less brightness).zip
- 2 main files included:
map_spain.tga
map_spain_thumbnail.dds - (416.58 KiB) Downloaded 455 times
Gracias a la ayuda de gforce he podido realizar el mapa definitivo de España, disfrutadlo.
- spain.zip
- Mapa de España definitivo.
- (484.3 KiB) Downloaded 482 times
installer attached for the definitive spain map above.
- Setup_spainDefinitive_1.0.zip
- (371.47 KiB) Downloaded 778 times
