Flagler's Florida
Flagler's Florida
I made a new map for myself to use. After building it, I thought, maybe some others would like to try it.
It's a mid size map. I made the Scenario pretty easy, I think playing at Robber Baron is the best challenge. There is plenty of resources and places to take them.
If anyone has ideas to make it better, let me know. It's not really finished, but was a fun learning experience.
It's built to commemorate Henry Flagler, who brought railroads to Florida.
Unzip to your My Documents\My Games\SMR\Custom Assets\XML\Scenarios
- Flagler'sFlorida.zip
- (202.94 KiB) Downloaded 1030 times
I played it and had a number of crashes. I finally got it up to Sept. 1869 when some auction was coming up and it crashed again, this time at the same place 4 more times, from a saved game. I ran 3 spyware/adware programs and found I hadn't done it for 2 weeks. 5 turned up. After that the map ran fine and I owned all 3 by 1916 with a worth of over $85,000,000.
Can this be called proff of one type of problem
Great map.
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
![Wink :wink:](./images/smilies/icon_wink.gif)
![Idea :idea:](./images/smilies/icon_idea.gif)
Great map.
I told you it was an easy map.
Would anyone that downloads this map and gets a crash, please post that you crashed. Please, like Snoopy, make sure you're not running any spyware/adware that might cause the crash. Crash info is only helpful if you're running a clean machine.
Thank you very much.![Smile :)](./images/smilies/icon_smile.gif)
attached is an installer for this map.
- Setup_FloridaTestBuild_1.0.zip
- (182.09 KiB) Downloaded 908 times
I tried to play this with my duals and noticed it would not load the duals. I looked in the RRT_TrainCars_FloridaTestBuild and saw there was mention to "Tender Cars' I removed this>
</szName></TrainCar></RRTGoodCars><RRTTenderCars><TenderCar><szName>Norris Tender Car</szName></TenderCar><TenderCar><szName>Planet Tender Car</szName></TenderCar><TenderCar><szName>Beuth Tender Car</szName></TenderCar><TenderCar><szName>Patentee Tender Car
Now I have the duals, but will the game crash???
![Image](http://i28.tinypic.com/es3y8l.gif)
I have no idea. Play it and find out. Then let us know.dwax wrote:I tried to play this with my duals and noticed it would not load the duals. I looked in the RRT_TrainCars_FloridaTestBuild and saw there was mention to "Tender Cars' I removed this>
Now I have the duals, but will the game crash???![]()
![Laughing :lol:](./images/smilies/icon_lol.gif)
Almost any time you edit a map your previous saves will crash. I say 'almost' because someone will have a time it doesn't. A saved map has certain things happening. If something to do with one of those things is changed, the game can no longer do it, and it just has software breakdown!
Talk to it nicely, apoligize for confusing it, and start the map from scratch. This poor game has enough problems...........
All reference to the TenderCars needs to be removed. The only time you should see a breakdown having to do with Tenders is when you set up a train. One problem could be the Events XML. It's universal. And the lack of Coal shouldn't cause a problem since you dont have any to begin with. The ZIP below has the changes needed and the Events XMl for this map. Just replace the existing ones with the ones in the ZIP.
As this is a test, I notice that the poor towns have to produce Food for 20 years before being able to ship it anywhere. And what they do produce goes out the back door.
![Shocked :shock:](./images/smilies/icon_eek.gif)
- FloridaTestBuild.zip
- (3.21 KiB) Downloaded 453 times
Re: Flagler's Florida
Has this map been finished and can I use it without the game freezing or crashing my computer.
