Borneo Island Map Final Release
Re: Borneo Island Map Final Release
Hi, I am having a bit of an issue. The installer seems to work good. When I go to play the map it crashes when loading. Any help would be awesome.
Thanks,
Greg
i7-3770 Ivy Bridge 3.4GHz
GIGABYTE GA-Z77-D3H Main board
CORSAIR Vengeance 16GB Ram
Western Digital WD VelociRaptor 1TB 10000 RPM 64MB Cache HDD
EVGA GeForce GTX 570 HD 2560MB 320-bit
Rosewill 750W Continuous 80 PLUS GOLD
7 Ultimate 64bit
Greg
7 Ultimate 64bit
If you had a clean UserMaps folder (no ither maps!!) it should start.
Sometimes it takes 3 - 4 tries to start. I think it is due to the large size of the map.
My starts the 2nd or 3rd try
PS let's hear from you if there is more trouble.
Thanks Jancsika,
cleaned out the custom maps folder and it started up first try! I will let ya know if I have any other problems.
Thanks again
Thanks again
Thanks,
Greg
7 Ultimate 64bit
Greg
7 Ultimate 64bit
Hi, Game just crashed after about 15 min of play. UGH !
Thanks,
Greg
7 Ultimate 64bit
Greg
7 Ultimate 64bit
I have the same problem with this map however it also happens with others as well. Just reload from the last autosave. You might even have to reload a couple of times but the crashes get less the further you get into this map. I gave up trying to figure out why the CTD's happen, accept them for being a pain and reload.
I normally go back 2 or 3 autosaves and try to play a different game.Just reload from the last autosave.
It helps. (Most of the time)
There are so many different things that
Hi,
Is it possible that the game is clogging up the memory? I am going to increase my page file and see what happens with that.
Thanks,
Greg
7 Ultimate 64bit
Greg
7 Ultimate 64bit
Hey Warll,
You should probably keep your measly comments to yourself.
Thanks,
Greg
7 Ultimate 64bit
Greg
7 Ultimate 64bit
OK Ward!
You owe an apology!
As for the memory. Try Gamebooster.
This will temporary shut down all the unnecessary programs.
Freeing up a little more memory.
You owe an apology!
- gamebooster.zip
- (906.2 KiB) Downloaded 809 times
Gamebooster does not work for me the map still crashes after playing for 20 minutes. I think it is because of the amount of new content in the map and my computer which had 8 gigs of memory and i have ran the 3 gig enabler, and windows 7 still cant handle it all.Jancsika wrote:OK Ward!
You owe an apology!
This game is so touchy anything can happen at any time.
I can Play rodea2007's other maps without a problem except this one is a lot bigger.
I turned up my page file to 4 gig min and 4 gig max. I turned off a few things. Playing with no crashes so far. Keep your fingers crossed...
Thanks,
Greg
7 Ultimate 64bit
Greg
7 Ultimate 64bit
HI,
Is what is the best city/town to start at. I'd like to hear some strat's for this map. This is proving to be one of the hardest maps I've played. GREAT JOB RODEA !!!
Thanks,
Greg
7 Ultimate 64bit
Greg
7 Ultimate 64bit
s
Have at least two AI opponent and buy them out before the end of the first Era.
That will give you some of the scenario goals that are hard to achive otherwise.
For Era Two, the passenger traffic is tricky. There is a passenger flow that goes counterclockwise.
The rest is a piece of cake
You really don't have much choice.what is the best city/town to start at.
