Middle East Final Beta Released
Post by snoopy55 » Fri Apr 13, 2007 9:21 pm
Just want to see if you were awake :wink:
I've got a few things about the game racing thru my mind...... woops, 3 file pile up on the hairpin curve....
Post by snoopy55 » Fri Apr 13, 2007 9:42 pm
I just tried something new with this map and wouldn't you know it, I chose the one with the most problems.....
Atani - the Installer doesn't have the Chickpea Depot or the Falafel Food Plant.
I need to look into something else on this map.
WOW
Post by Slappy Da Clown » Fri Apr 13, 2007 9:43 pm
Damm Snoop
I think that fix is gonna work, It dont crash when you mouse over it with a depot now, BUT, 2 Billion dollars for an annex is a bit much eh ? lmao
Dell Dimension 8400
3GB Memory
Post by atani » Fri Apr 13, 2007 10:39 pm
snoopy55 wrote:I just tried something new with this map and wouldn't you know it, I chose the one with the most problems.....
Ooops... I will fix that and post a new installer tonight.
Post by snoopy55 » Fri Apr 13, 2007 10:45 pm
Here is the data you'll need. I had to search some stuff I had been working on a couple of monthes ago.....
Chickpeas.zip
(997 Bytes) Downloaded 352 times
Re: WOW
Post by snoopy55 » Fri Apr 13, 2007 11:14 pm
Slappy Da Clown wrote:Damm Snoop
Now I am inocent!!! There was no Chickpea Annex in the installer, so you must have one in your RRT_Depots.xml GLOBAL with that price tag.
But hey, look at it this way, they can get BIG BUCKS for their oil that we turn into gas, why not BIG BUCKS fortheir chickpeas that we turn into gas...... :lol:
( I just paid $2.86 / Gal for unleaded plus... the unleaded was $2.91! Summer prices you know......)
Post by atani » Sat Apr 14, 2007 5:53 am
new installer posted which includes the above fixes...
Post by snoopy55 » Sat Apr 14, 2007 6:59 am
Mike - minor problem.......the Chickpea Farms are demanding Chickpeas and producing Food. Sounds good, but we don't deliver seed....the farmer is on his own there....... :wink:
and please don't make the same mistake i did, input food, output chickpeas :roll:
hmmmm
Post by Slappy Da Clown » Sat Apr 14, 2007 9:12 pm
Chikpea farms require food ?( I may not have noticed it called something else ). It is possible to play this map without using the chickpea farms. But, it seems like very soon after you get your 1st metropolis it crashes. Ive tried it several times with the same result.
Dell Dimension 8400
3GB Memory
Post by K-class » Sat Apr 14, 2007 11:21 pm
Hello,
see my post http://www.hookedgamers.com/forums/view ... 6585#16585
Also in the global RRT_Goods.xml the files below dont exist in:
Assets/Interface/Goods/
Assets/Interface/Cars/
reference to chickpeas
Snoop55 re your post above re download Chickpeas.txt
refers to Assets/Interface/Goods/icon_grain_32.tga these don't exist
So looks to me if there is another installer / map that we need to install??
d53642
Post by d53642 » Sun Apr 15, 2007 2:25 am
those shhould exist inside an FPK file, there are alot of train cars and graphics that you can't see unless you open the default fpk files.
I know it exists because I am the creator of this map :)
I finally got my RR working somewhat on vista but not well enough to finish a whole game.
Daryl
Post by Warll » Sun Apr 15, 2007 3:00 am
d53642 wrote: I finally got my RR working somewhat on vista but not well enough to finish a whole game.
Daryl
thats great news! I really missed you when i came back two months ago.
Post by K-class » Sun Apr 15, 2007 3:07 am
Thanks d53642
They may exist but the global file is not pointing to the right place thoe.
Which FPK have you got that in. I ask as I dont see a FPK for this map.
Post by snoopy55 » Sun Apr 15, 2007 6:26 pm
K-class - somewhere on this humungis forum it was found that the Assets/Interface/Goods/ is really ignored. If you go into the original files, \Sid Meier's Railroads!\Assets, you will not find a folder called 'Interface'. There are two files called Interface0.FPK and Interface1.FPK, but that's it. It has never (to my knowledge) been discovered what is going on at this point, except thet the game does find what info it needs and uses it. Some mappers leave off that part and it still works.
Post by snoopy55 » Mon Apr 16, 2007 5:11 am
I've got the bugs removed from this map. The mill and the Metal Works Factory were set to be put in the Forest, of which there are none. The Metropolis wanted 'Subway Rails', so it crashed. Now, it can run as I have it, but it needs something more, and I need you peoples help.
We have the following Goods:
Passengers
Mail
Food
Manufactured Goods
Livestock
Fish
Coal
Oil
Steel
Chickpea
Iron Ore
This leaves:
Passengers
Mail
Food
Manufactured Goods
As what can be delivered.As it's set up now:
Villages:
Passengers
Mail
Town:
Passengers
Mail
Food
City:
Passengers
Mail
Food
Manufactured Goods
And Metropolises:
Passengers
Mail
Food
Manufactured Goods
Now, there were 2 other items, one, Subway Rails, which caused CTD, and two, Automobiles, which left a HD address as part of 'Demands' for it. (Now you know what that is if you come across it)
What I need is some suggestions as to what to add to the map as Finished Products. Any ideas? The map is working now, I just have to get the Data to Atini so he can figure out how we're going to do this.
