Well, locomotive evolution wise you could go SD40-2(1972) then SD70 (1992?). These were biggers steps in evolution. I remember the SD50 and SD60 fondly but they didn't sell HUGE like those other 2 models. And once again the exterior look of the 3 is practically the same.eilelwen wrote:well still working on the smoke, and it also seems the sounds arn't working yet so still having troubles, figuring out where those links are made.
Same with the texture.
Gonna include a better shot of the GP7 though.
and would you guys rather have the sd60, or the sd40-2
the sd60 fits in with my plan, I can make the sd40-2 work, but it won't be as big as an upgrade as the sd60 would be.
Diesel Mod.
I have the trial, but its useless to me. I have windows XP pro x64. there is only one version of max I can use. and the niftools will NEVER support it. So unless someone with max 5/6/7/8 decides to help. there is nothing I can do.
Loco wise I think I'm gonna stick with the GE AC6000CW-1994, although if enough people want a change its not really a problem, as I havn't even started those yet.
although production wise the AC6000 there is only a few hundred. the AC4400 would be a better choice outa the two.
The reason I want to go with these two is they are visually different in there standard outfit.
Yeah tell me about it. I built myself a new 64bit system this June with XP64 OS thinking for once i would be ahead of the curve and in good shape. But it seems we are TOO far ahead of the curve and there is a TON of stuff that won't work with it. Our printers and kodak digital camera are hooked up to the OLD system to work and my Norton Systemworks is useless, etc etc....
hehe true, all I would have to do to be satisfied is change the name hehe.eilelwen wrote:I have the trial, but its useless to me. I have windows XP pro x64. there is only one version of max I can use. and the niftools will NEVER support it. So unless someone with max 5/6/7/8 decides to help. there is nothing I can do.
ok so the SW1 went off to Texture Artist so he can work his texture work
and today I modeled the AC4400, I still need to do some of the small details but its mostly done.
I relize its hard to see whats going on, I will make some better renders tommorow.
![Smile :)](./images/smilies/icon_smile.gif)
- AC44001.jpg (26.94 KiB) Viewed 10230 times
- AC44002.jpg (31.7 KiB) Viewed 10229 times
soon will depend on my texture artists, I could have all the models done and ingame in a few days time, but actually getting textures on them will take quite a big longer.
Ok, even though this is a deisel mod I had to add atleast one steam engine.
So here is a shot on my progress on modeling a 4-6-6-4 challenger. I know it dosn't look like much, but thats also because I havn't finished it or done the transparency.
- Challenger.jpg (112.67 KiB) Viewed 10133 times
My man do I have a site for you and any others working on engines:
http://paintshop.railfan.net/home.html
I hope it helps in your never ending endevers....
