The Last Edited from West Sumatera Map
Borkvald
Three villages to metropolis
Post by Borkvald » Fri Apr 11, 2008 10:49 am
Starting near one of the container ports is probably the key. Starting in Painan I managed to finish all goals in 1936. Robber baron, hard, 2 AI's.
Re: Three villages to metropolis
Post by Rodea2007 » Fri Apr 11, 2008 11:26 am
Borkvald wrote:Starting near one of the container ports is probably the key. Starting in Painan I managed to finish all goals in 1936. Robber baron, hard, 2 AI's.
You allright Borkvald but if starting in Bonjol or Solok you must collect more money in order to can build depot at Padang
For best viewer try to use this setting in options/Grapich
Use this setting to best viewer
best viewer.jpg (235.02 KiB) Viewed 11239 times
All AI's Was Bought Out<br />Robber Baron, Hard 3 AI's
AI's Bought Out.jpg (343.28 KiB) Viewed 11239 times
Asian Buildings Model for next map
asian model buildings.jpg (710.74 KiB) Viewed 11262 times
Offshore oilrig with that setting
Borkvald
filesize
Post by Borkvald » Fri Apr 11, 2008 12:24 pm
My graphic setttings are optimal - there's no sence in uploading 700 kb when 150 is enough.
samuray111
Post by samuray111 » Wed Apr 16, 2008 10:20 pm
great job
awesome :)))
thank you..
walt0603
Re: The Last Edited from West Sumatera Map
Post by walt0603 » Mon May 12, 2008 2:00 pm
Hello together,
unfortunately the map won't start. The starting process ends in a CTD.
Yesterday i tried the following:
Installation of West Sumatera Scenario Vers 1.1. Then deleting the WS-Files in .../MyGames/Sid Meiers Railroads. At last installing the New West Sumatera Map. The game ran well.
Today I had a CTD again.
I hope anybody can help me (if you understand my poor English)
Greetings from Germany
Walter
Post by Rodea2007 » Tue May 13, 2008 2:44 am
walt0603 wrote:Hello together,
Walter
Hello Walter
To test this map, please make clean Install-->rename Sid Meiers Railroads! for ex. Sid Meiers Railroads!bak then make new folder with name Sid Meiers Railroads! copy setting.ini from old SMR folder to new SMR folder then play SMR with original map. After that exit from game and run West Sumatera Installer, that is only test, should be West Sumatera no CTD after Installed with others map
Happy enjoy it...
walt0603
Post by walt0603 » Tue May 13, 2008 5:00 am
Hello Rodea2007
Thank you for your quick reply.
First of all I have to describe my system's settings:
I'm running Vista Ultimate SP1. Therefore I patched my SMR.exe with 3GBenabler to get no CTDs when I play my maps, SMR runs very good with it.
And now my test:
I did a clean install by renaming the folder in MyGames, installed WestSumatera.
With the patched SMR.exe the map did not start, with the original SMR.exe it started well.
I'm going on testing the map later this week.
Thank you again, Rodea2007.
IndianaJones
Post by IndianaJones » Wed May 28, 2008 6:47 pm
Thank you Rodea for the great map. Im off to play it now. Bye bye!!! :D
Post by Rodea2007 » Thu May 29, 2008 8:42 am
IndianaJones wrote:Thank you Rodea for the great map. Im off to play it now. Bye bye!!! :D
Have enjoy with my map.... :?
Indiana Jones is my favourite movies and games
Aleksander
Post by Aleksander » Mon Jun 16, 2008 8:26 am
hello
I cann't even get it to download from the two places listed for some unknow reason please help
thanks
Aleksander
Post by Rodea2007 » Mon Jun 16, 2008 10:21 am
Aleksander wrote:hello
thanks
Aleksander
click the address below :
http://rapidshare.com/files/103992197/S ... o.exe.html
then choice free download, that's all then enjoyed with my map.... :lol:
Aleksander
Post by Aleksander » Mon Jun 16, 2008 2:46 pm
hello
I had use a different server to download from instead of aol
now I get an error message after conecting the two citys for next phase of the game
thanks
Pete
Post by Pete » Sun Aug 10, 2008 12:03 am
Hi Rodea.
First let me say that I am your number one fan; the maps of yours are spectacular in their originality.
I am one of those, that have had big trouble playing the more complicated maps. I am lucky to get more then 15-30 minutes before they crash. Not just yours, but others as well. Now that the SAM's are coming out, I've been using them with no stuttering; no crashing; not a hint of trouble.
I am working as the tester on your West Sumatera as a true SAM, and so far; in the testing stage; it has run for hours trouble free. I really hope, that any you do in the future, could be done in the SAM format.
After 2 years; I think we finally have a fix for this game with the SAM's, and with your talent, it only gets better.
Pete
Post by Rodea2007 » Mon Aug 11, 2008 3:44 am
Pete wrote:Hi Rodea.
Pete
Hi...Pete
Thank you for your comment, your comment make me praised, and thanks again as tester WSM-SAM, just I want to do the best to this forum with my small knowledge .... :P
Bunit
Post by Bunit » Wed Jan 21, 2009 12:42 am
Rodea2007 wrote:I have been uploaded The Last Update From West Sumatera Map at address
EDIT//...OR. http://model-railroading.net/SMRfiles/S ... enario.exe
This addres from DR. Frag
Thank's DF for it
The Last Update this Map provided adding new Industry Offshore Oilrig
This Installer support Multilanguages, it does mean you can run this Installer with what language you used
All error in Map before this has been repaired, but if you get error don't hesitate to post what your problem
I was tried to Install this map at anothers computer, until nows that work's fine. I hope so you can success install and play's this map without error.
Good lucky.... :wink:
Beautiful map i love all the new stuff you used for this map the port the oil depot and the new trains.
I would love to be able to do this sort of thing. Is it easy to make a map I havew been reading about it and when i look at the terrain editor part in the game im not quite sure what to do I there any tutorials on map making.
