LongShot New Map
vzbob
Post by vzbob » Sat Mar 29, 2008 1:13 am
Jancsika wrote:
Ok heres my screenshot it dont have the hospital icon there at all
I played the scenario for hours.
I have to apologize to vzbob for the run around. :oops: I just relearned something that was discussed before and quite forgotten.
I hope thou that you had some fun.
PS: A corrected version 1_02 was uploaded.
No apology needed these thing happen and we are all learning about this game all the time its a good map that i can play without any crashes or freezing up for some reason i cant make any maps at all the editor always crashes when i try so i just play the other maps that i can get to work.
Post by Jancsika » Sat Mar 29, 2008 1:55 am
Yes it does. For some strange reason you can not make a new map in the terrain editor only when the game is freshly installed and no scenario maps were installed yet. But “Start a new map from a scenario map” button works. Try that, once you have it you can edit both the map and the XML file as you wish.
Post by snoopy55 » Sat Mar 29, 2008 2:27 am
This kind of seemed odd to me as I've played with it myself with a loaded SMR folder. It took the original City OK. It took the second City with the Smelter in place. When I laid the third I placed every Industry in the list. No problem.
Where does it crash for you two?
Post by Jancsika » Sat Mar 29, 2008 2:46 am
Snoopy! I think you are misunderstanding me: I was talking about creating a new map in the Terrain Editor. It was discussed in an old thread that I copied, below.
Big Papa and I have also seen this problem but didn't know what caused it. So to make starting maps more convenient, I have created templates that we load whenever we want to start a new map. These templates include the starting map and the xml for all Goods, Industries, TrainCars, and Trains. So now I am making them available for you!
The attached ZIP file contains a map directory for each of the standard map sizes, and a small utility program I wrote inside each directory that creates a clone of the scenario with the name you specify.
Using these saves you the first couple steps of creating a new map in the editor, exiting, editing XMLs to include all industries, then relaunching the editor.
Using the cloning utility programs, you can quickly create as many maps as you want with the click of a single button!
TemplateMaps.zip
Description: Template maps for all standard map sizes
Download
Filename: TemplateMaps.zip
Filesize: 331.35 KB
Downloaded: 8 Time(s)
Post by snoopy55 » Sat Mar 29, 2008 6:55 am
As I'm understand this, and correct me if I'm wrong, with a game that has Moded maps installed, the Editor built into the game crashes?
From what I see in that quote, they made map bases and then loaded the XMLs with all that was available. If you could create a second copy of the main SMR you could load all the FPKs and pack all the Mods into the original XMLs and you would have the full set available to you. (avoid the trains tho, to much......)
A way to use Mods without all of that is to list the Originals you are going to use, and use them. Then for every Mod you plan to use, use one of the left over Originals. When you're finished, go into the XMLs and replace the left overs with what you intended.
Where was that post you quoted? It may make a bit more sense to me if I saw the posts before and after it.
I'm sorry if I'm confusing myself :shock: .
Post by Jancsika » Sat Mar 29, 2008 2:47 pm
http://www.hookedgamers.com/forums/view ... highlight=
Jancsika :wink:
Post by snoopy55 » Sat Mar 29, 2008 3:09 pm
OK... don't remember it, but then with my system crashing several times in the last year I've lost whatever I did.
In the last post I did write this:
Sounds great! Just to update my experiment, I put my stripped XML, Goods, Indusrties, TrainCars, Depots and Cities. Then Edited the Blank Scenario for those. I got to choose what I wanted from a full list, but it still extracted all the tenders from the GLOBAL and added them.
So, I guess I check out this new ZIP. You would wait till I fought for 6 hours with the Central Mexico map.... saves Cities and Industries fine, but likes to CTD right after saving the map.
I would assume that since I didn't mention it, the map was correctly saved, the game just crashed after saving. Is anybody using an edited set of XML blanks? Those sit in the Original Scenario folder. I think that is what I was playing with. Playing with it since this thread shows that if you add the Mods to the blanks, you have to add the FPKs to the Original Assets folder.
Post by Lowell » Sat Mar 29, 2008 5:16 pm
The trouble is in the set of globals. I had to go back to a clean game and a single map system. I also watched many page faults being made in the global setup when the game was running. So instead of the game trying to run and calculate everything, the system was busy recording errors. I noticed other troubles appear after the smri update, it seems to have gotten worse. When you make a new map...you have to shut down the game and edit the xmls real quick. It loads everything in the kitchen sink, all the BNSF trains and car content. Tons of tenders...those will cause a crash if listed in the train cars section unless you have made new tenders. So all that has to be stripped out and start with the blank games xml list when you start a new map.
Post by snoopy55 » Sat Mar 29, 2008 6:52 pm
You people must have something set up wrong. I just did a map with 4 cities, 7 Industries and 11 Annexes. It saved fine, exited the Editer fine (went to Desktop of course) and played fine, with no editing. It does have all the available TrainCars, Tenders and Engines in it, but is that really a big deal? I also did not get any error logs.
You have to go in and do editing anyway as the RRT_Cities.xml needs to have the cities Production Modifiers changed to match what your final products are.
Do these crashes happen when you save the map prior to exiting the editor? And if so, what part of the Editor?
Post by Lowell » Sat Mar 29, 2008 11:51 pm
I think they are refering to when you make a new map in the editor...the xml's that are created have all the industries, train cars, tenders and other stuff added to the newly set of maps xml lists. Then after they start making additions to their maps files they don't remove those "extra" items and it can cause crashes having tenders listed that are already listed as global...we have known that for over a year now.
It is that trouble that I think they are refering. Any new maps need to be made with the default games xml list first. Also the random event crashes don't happen in a default game either...so something is causing the trouble. I think once maps are built self contained, it will clear all the conflicts out of the custom assets global set of files. It could be something that has the same name in an FPK somewhere...it will take forever to weed through everything/map/content.
My thoughts are the Sam project and/or the Clean Install maps may just be the ticket.
EDIT// In the above statement I refer to the global set of files. As I don't use those anymore...maps have to be self contained and run in a default game load. The editor never crashes out on me and I still edit some pretty full/huge maps...but...it used to before I switched.
mutantz
Post by mutantz » Fri Apr 18, 2008 6:57 pm
This happins when i run this map,the arrow disappers
CalmDragon
Post by CalmDragon » Fri Apr 18, 2008 8:31 pm
mutantz wrote:This happins when i run this map,the arrow disappers
Yes, the description line is a bit long and pushes the arrow behind the picture. 8)
motherboard : Asus P5N-E SLI
processor: Dual Core 2.4 GHz
memory : 2046MB
operating system: winxp media
Post by snoopy55 » Fri Apr 18, 2008 8:49 pm
Jancsika - the reason this is happening is the long <szSubtitle> you have. Normally this is a few brief words or a from-to date of the map. NE UK Hard also has this problem because the map name is to long.
It might be good just to leave it as Version 1.02, or just the dates.
Post by Lowell » Fri Apr 18, 2008 8:56 pm
That should not happen. The info should scroll up and down...not side to side. My intro is much longer than yours and it doesn't do what your menu is doing. That button is to go from map to map in his game...that button should not be removed...now he has to scroll left through all the maps to get back to yours, instead of going left and right.
Some type error is throwing off the interface browser. Again...my intros are wayyyy longer than yours, and the interface browser behaves just fine with them.
Post by snoopy55 » Fri Apr 18, 2008 9:13 pm
Lowell, the first line is the name (<szMapName>). The second line is a brief discription of the map, as I said, dates or versions. (<szSubtitle>) The last part is the part that can be scrolled thru which is <szDescription>.
The first two cannot be scrolled thru.
