Industies and Goods(ratio)
Well, it all comes down to the fact that Firaxis created this game to work the way it does with what it had, not to work the way we want it to with what we have created.....
But hey, who thinks beyond the next dollar bill anymore?
Note: this is aimed at Firaxis, not us....just covering my wording........
Nope that won't work.
You get one Industry.xml list per scenario...the steel mill can use coal for One input not two...the game won't know what you want the coal to do.
One input means one output per industry...here is where I say the game won't 'split car loads.' You could use Ore for the steel and leave the coal for the iron.
An industry can have more than one output...as many as you like. But remember five goods out means five bulk goods in...unless you do the percentage thing using two inputs for one output bringing production to max.
Yes, this can work, but both would have to be different industries with different names.Jancsika wrote:Has anybody tried this?
Steel Mill
Input: Coal
Output: Iron
Steel Mill:
Input: Coal
Output: Steel
(Or any other variation?)
That is two steel mills in one city. The in-game editor won't do it, but can be edited in the XML file?
Iron Mill and Steel Mill, for example. Coal deliveries will be split between the two.
Snoopy pointed me here.
I'm currently dealing with the problem that I can't have an industry
accept 1 good and convert it into 2 different goods. - As described in this topic.
I think I need to do some tests.
This should not be hard to program for the Firaxis people.
The only changes needed are in the way industries accept and convert goods.
A few small tweaks would do the trick and would open up an entire new world
of possibilities for us.
Actually all of that is very basic stuff in the game Locomotion.
Mappers are even able to tweak percentages of 2 different required inputs
to produce 1 output. (Or vice versa: 1 input to produce 2 outputs).
Don't know much yet, but I'm pretty sure of what I do know...
I think. Lemme check that.
Sofar I've tried the following formats.
None of them work.
<Production>
<Resource>
<Input>Coal</Input>
<Output>Iron</Output>
<InputOutputRatio>0.50</InputOutputRatio>
</Resource>
<Resource>
<Input>Coal</Input>
<Output>Steel</Output>
</Resource>
</Production>
<Production>
<Resource>
<Input>Coal</Input>
<Input>Coal</Input>
</Resource>
</Production>
<Production>
<Resource>
<Input>Coal</Input>
</Resource>
</Production>
<Production>
<Resource>
<Input>Coal</Input>
</Resource>
</Production>
I am looking for a way to create a double output entry.
Something like this:
<Production>
<Resource>
<Input>Coal</Input>
<Output>Iron; Steel</Output>
</Resource>
</Production>
Has anybody ever seen more than one entry per tag, as shown above for the output?
If so, I'm very curious for the symbol inbetween the two. If any.
Because frankly, testing all the possibilities on that would take forever.
The last mentioned format has been tested and failed.
Also a variation where the space was dropped, <Output>Iron;Steel</Output>
did not work.
Bah.
None of them work.
<Production>
<Resource>
<Input>Coal</Input>
</Resource>
<Resource>
<Input>Coal</Input>
</Resource>
</Production>
<Production>
<Resource>
<Input>Coal</Input>
<Input>Coal</Input>
</Resource>
</Production>
<Production>
<Resource>
<Input>Coal</Input>
</Resource>
</Production>
<Production>
<Resource>
<Input>Coal</Input>
</Resource>
</Production>
<Production>
<Resource>
<Input>Coal</Input>
</Resource>
</Production>
did not work.
Bah.
From the discussion on this topic before, my guess would be that you are going to have to go with something that looks like City Iron Work and City Steel Works. where the ratio would be one. on each. The coal on delivery gets divided between the two and four cars of coal become 2 cars of steel and 2 cars of iron. But since steel is made from iron, and not from coal, I have a hard time following your logic.
2 GB PC5400 DDR2 Ram
MB nVidia nForce 680i LT SLI
GC GeForce 7300GS 256MB PCI-E
HD 250GB + 500GB
OS Windows XP/SP2/32 bit
HD 250GB + 500GB
- Star Ranger4
I agree with that 1 + 1 =1, but add in that after it has 8 or so loads of one of the Goods not used, it won't accept anymore of that Good until you get some of the other in there . Hey, those stockpiles can only handle so much.
Regular loads should also be the same, get a set amount of Goods produced and you can't drop off any more of the input Good until you get the output Good removed.
Make two different industries, you can place both of them in the same town and the cars coming in would get shared.
Just take the smelter or whatever, make two copies and two different names. Place both of them in the same town. Then set one for iron the other for steel. Better yet...I have a large industry building that looks like a coke plant...sort-of...if you want I will post it. It is a tank repair factory in my Georgia map.
Better yet, place a coke plant in the next town, then move it to the steel plant. On the Florida map I imported my titanium.
- coke tower in Chicago...torn down in July 2004
These were the unloaders, wow were they gigantic - 89huletts.jpg (25.03 KiB) Viewed 8781 times
- the furnace tower in Chicago
- furnace4.jpg (28.54 KiB) Viewed 8781 times
- this molten KMS vessel was from an abonded coke plant in Germany
- KMS Vessel.jpg (40.33 KiB) Viewed 8781 times
- this is really three plants the coke plant part is in the middle...all of the plant areas could not be in the picture...place must huge...
Could you amagine working here? By the time I found my work station it would be time to go home. - ruhrberechtigungsschein_900px_300kb.jpg (294.73 KiB) Viewed 8781 times
