Green Energy Map
I thought we were talking about the same thing but you seam to have gotten me lost. When you talk about rar files what do you mean by that? I do not know of any maps that use the rar. file format to store any assets. Unless Anti's installers have built in compression B&R is the only map I know of to compress anything. What I meant in my first post was that since the Santa map has the second most custom content it makes sense for it to be large.
green energy [edit version]
.......................mr snoopy55 with your permission may i point out [and who knows could be the cause of the odd ctd with some people] as with the original 'green energy' your edited version seems to have overlooked the following: the 'cityies xml' shows 2 gamma cities [one is town the other is city and only one appears on map] then there is ipsylon and epsylon and finally in the 'names xml' two cities are named that are not in 'cities xml' namely 'psy' and 'tao' .. in 'names xml' only one 'gamma' and no 'epsylon' appear - not for one minute am i 'knockin' you guys for without you and all your hard work SMR would be long dead - i enjoy the game and spend endless hours playing the thing [forever changing the xmls to my liking - use the '4000' single engine in green energy along with random map] ....many thanks for your time - cheers sean sutherlandsnoopy55 wrote:After doing a bit of editing, removing unneeded cars and those nasty TenderCars, I ran it and it worked fine. Here is the edit version:
Thanks to “sean sutherlandâ€
- green energy.zip
- Green Energy version 2.0
- (386.49 KiB) Downloaded 812 times
sean sutherland - no problem with pointing things out. I didn't get into the city names, just the Goods and related XMLs.
Jancsika - no problem at your end either, this is how we get great maps to keep this game going, we all pitch in.
- K-class
Thanks Jancsika great map also good combination here and will play will for most users. Same as CeeBee51
Played Green Energy version 2.0 till the end.
(I added my own trains and I had to remove the customised Passenger Car and Mail Car for my global train cars to work. Added in case you get a CTD with your trains)
Green Energy 2.0 installer attached..
- Setup_GreenEnergy_1.0.zip
- (272.86 KiB) Downloaded 1223 times
Re: Green Energy Map
This is the latest, and working, Green Energy SAM.
Warll, you might want to update your database, the one you have posted is from the old days of FPKs and does not contain all the material needed.
- Green_Energy 2.0_SAM.7z
- (2.49 MiB) Downloaded 797 times
Thanks Snoopysnoopy55 wrote:This is the latest, and working, Green Energy SAM.
