tracks
chips2481
Post by chips2481 » Mon Jul 09, 2007 5:44 am
what is the open and then load save file trick?
p5n32-sli deluxe
pentium d 950 ES w/ HT OC to 4.0
2 gig corsair 5400ul 3-3-2-8
550 watt antec neo
antec p180 case
Quadro Plex VCS
Post by snoopy55 » Mon Jul 09, 2007 6:20 pm
You go in and start the map from which your save was made, then click on the menu in the upper right corner and click on 'Load Game' and choose the game you saved. I don't know if others have this problem, but the graphics on my screen tend to get fuzzier the more I start and load maps without exiting the game. :twisted:
chips2481
Post by chips2481 » Tue Jul 10, 2007 12:15 am
this is the only difference I found. Looks like the picture for the sky doesn't get loaded so the water doesn't reflect it.
Post by Warll » Tue Jul 10, 2007 1:08 am
Nope that is most likely a shader error since mappers do have an option to change the water's colour it likely has something to do with that.
keotaman
Tracks - Virtual Memory
Post by keotaman » Tue Jul 10, 2007 2:42 am
snoopy55 wrote: ... but the graphics on my screen tend to get fuzzier the more I start and load maps without exiting the game.
Snoopy, I asked this before & you never answered -- what is your pagefile (Virtual memory) set at? Mine was originally at 730Mb, & SMR would often require about 950Mb. This "on the fly" change in virtual memory caused many graphic & ctd problems with my system. Granted that I only have 512Mb ram, it now works quite well, since I set my pagefile to 2048Mb. I suspect that anything in the order of 1200-1500Mb will also work well. Anyway, it can't hurt.
Post by snoopy55 » Tue Jul 10, 2007 4:59 am
keotaman - sorry bout that, I get distracted sometimes :twisted:
I have 2024 on one drive and 3072 on another for a total of 5096. I may put 5120 on one drive and remove the other two. I've only recently seen it go over 800Mb virtual and 950Mb regular, and I have 3Gb memory at this time. I started doing some research on maps as to what needed to be loaded first to cover all mods and what maps use what materials, and my game has gone haywire. The screen is breaking up in fan-type shapes of different colors. I lost multi-track station capability and had to reload the game. I'm on my fourth reload, and I'm getting frustrated. I'm going to have to go over the forum and search for solutions while writing a paper on it. Buggers :evil:
chips2481
Post by chips2481 » Tue Jul 10, 2007 11:15 am
so you guys are making your own levels. I could get into that, where can I download the editor?
p5n32-sli deluxe
550 watt antec neo
antec p180 case
Quadro Plex VCS
Post by Warll » Tue Jul 10, 2007 12:46 pm
how could you have found this site without also finding our maps! Just look in the mapping section for a 1337 selection.
Post by snoopy55 » Tue Jul 10, 2007 5:00 pm
chips2481 - there are two requirements, follow these instructions (found both in the forum and in Wiki):
How to enable map editor: First install patch 1.10, then go into your game folder (usually: "C:\Program Files\2K Games\Firaxis Games\Sid Meier's Railroads!\") and open the shortcut "Settings.ini" and add the line: "EditorEnabled = 1"
And read the forum for information on do's, don't's, can's and can't's. READ, READ, READ :!: And then read some more. Open maps XML and see how it's done, and watch for certain required editing of the XMLs. Ask questions and post your map to be examined and run. Simple :!: (ya right :twisted: )
Don't be put off. The above is true and helpful, but not scarey. While intrcate maps are great, they can be simple and still be fun.
Go get 'em :!:
keotaman
Post by keotaman » Wed Jul 11, 2007 1:34 am
Warll wrote: ... for a 1337 selection.
What does this mean?
Post by Warll » Wed Jul 11, 2007 1:47 am
:twisted: Thought that might fly over your guy's heads. In short 1337 is 'leet" speak for leet, leet meaning elite. For more heres a wiki link: http://en.wikipedia.org/wiki/Leet
keotaman
Post by keotaman » Wed Jul 11, 2007 2:22 am
Interesting, thanks War11.
However,
(#4r17%, n07 0b5$(4710n, 1$ 70 b3 P3$1r3P.
(Clarity, not obfuscation, is to be desired.)
Post by Warll » Wed Jul 11, 2007 3:42 am
|-|@! `/0|_| +|-|0|_|6|-|+ 1 \X/|20+3 $0|\/|3+|-|1|\|6 |_|$3|=|_|| [)1[)|\|'+ `/0|_|!
http://home.no.net/hellshl/main/translate.html
chips2481
Post by chips2481 » Wed Jul 11, 2007 5:51 am
you know I have been able to translate those myself when I see them but didn't know there was a translator :!:
p5n32-sli deluxe
550 watt antec neo
antec p180 case
Quadro Plex VCS
