Basin And Range map
Water??
Got this error every time I open the map it shows up covered in water. Sometimes its just parts of the map, some times its the whole map, dependes where the starting position is. Also when I try to exit to main menu it causes a CTD. Any thoughts???
- HisAlterEgo
I too have a CTD every time the map tries to load. I used notepad ++ and all xml's in this scenario have no errors. In the globals however, there seems to be just errors where it doesn't recognize the dashes over the letters e and i nor the umlauts (spelling?) over the letter u. This affects the Global Names_NLD, Names_FRA, Names_ESP, and Names_DEU. In the Names_ESP, I didn't write the line # down but it's in the 600's, it reads as follows:
<TextKey>
<Tag>Tag_France_name_Paris</Tag>
<Text>Paris&amp;amp;amp;amp;lt;/Text>
so I fixed that up with the closing "</Text>"
Also, line 646 in this same file has a mismatched tag </Text> as extra where it's not needed.
I don't think these make any difference as the game still crashed when I fixed them all and tried to load it several more times. Anything I can send you from my files or should I just hold for now?
<TextKey>
Intel P4 3.4 Ghz
2 GB DDR2 PC2 4200 SDRAM 533 Mhz
256 MB GeForce 6800 GTO
XP Home
XP Home
Re: Water??
You will need to go into your Graphics settings in the Options menu and change your Shaders to Medium. Low Shaders cause this "flood" problem. We will try to get a map together that works with Low Shaders.akerkhecker wrote:Got this error every time I open the map it shows up covered in water. Sometimes its just parts of the map, some times its the whole map, dependes where the starting position is. Also when I try to exit to main menu it causes a CTD. Any thoughts???
- K-class
Thanks Big Papa
I have installed into a test folder and only get
XML\Sceenarios\ etc and only the XML's no fpk and resource files are we sure there are other files and where are they as I cant see them.
K-class,
It sounds like 7-Zip doesn't want to run on your machine. Are you running Vista?
For those of you who are having trouble with the installer extracting the FPK files, here is a 3-part Rar volume that contains my CustomAssets directory. Rename your current CustomAssets directory, and extract this one in its place.
You will have to find a Rar extractor for your OS such as WinRar or WinZip. Or maybe Vista already supports extracting from Rar archives?
Hope this works better for you.
- BRCustomAssets.part03.rar
- Basin And Range CustomAssets directory -- part 3 of 3
- (7.52 MiB) Downloaded 536 times
- BRCustomAssets.part02.rar
- Basin And Range CustomAssets directory -- part 2 of 3
- (11.44 MiB) Downloaded 503 times
- BRCustomAssets.part01.rar
- Basin And Range CustomAssets directory -- part 1 of 3
- (11.44 MiB) Downloaded 548 times
- HisAlterEgo
I noticed there was no uninstaller with this, do we just delete this particular scenario and replace our custom assests folder with the back up I thankfully made?
I'll also try using your provided custom assests folder and see if that works.
Looks like it put all the fpk's in mine and I deleted the Basin and Range Demo map thinking there may be a conflict but to no avail.
Intel P4 3.4 Ghz
XP Home
XP Home
I started to load nitrates and the screen pop up said that the ( clothing_Car_bnsf_NORM and SPEC files are missing.)
EDIT//I too would rather have the files and not have an auto installer. My Florida map I am working on has started to crash for no reason just after loading your files. No biggie...I saved my global custom assets xml files...I am going to have to reload those.
I attempted to play the game and got the map below. I uped my virtual to 4Gb and uped my memory to 3Gb, same thing.
Problem solved, read the instructions in the first post....Sorry guys.
- BasinAndRange.jpg (58.89 KiB) Viewed 12906 times
- K-class
Hello Big Papa
Yep your installer has a bug
After downloading your 3 part rar the below FPK's is what was missing from the installation
SDSTrains0.FPK
SDSIndustries0.FPK
SDSInterface0.FPK
SDSTrainCars0.FPK
The games starts and plays ok at present. Love the new trains and the layout.
dwax save to download. Back up your xml as you prob have cusomised them.
Make sure you have those 4 files above after install in My Games\Sid Meier's Railroads!\CustomAssets
SDSTrains0.FPK
SDSIndustries0.FPK
SDSInterface0.FPK
SDSTrainCars0.FPK
- K-class
Map played well up to a point and CTD, restarted and another random CTD
Now wont load a saved game and this is the second time that that this happened.
I did not catch what caused it was prob another random event.
I would call this map BasinAndRange RC1 (not a finished product)
Love the forklift that's new.
I will dig around in the xml's
- K-class
checking RRT_Goods_BasinAndRange.xml
missing end tag for Gold </Good>
missing start tag for mail <Good>
szClass should be szName
correct
and in the goods file twice
My saved map now loads and plays. Well keep beta testing this map.
<Good>
<szName>Gold</szName>
<szClass>Mail</szClass>
</Good>
correct
<Good>
</Good>
<Good>
<szName>Mail</szName>
</Good>
<Good>
</Good>
