Post
by atani » Mon May 07, 2007 6:07 pm
Slappy Da Clown wrote:Works good now guys. Played to a finish. How does he stretch time ? It makes for a much more playable game I think. That is one of the things I liked better about RRT2. The time on this game ( except for this map ) seems to run faster.
I will rebuild the installer based on Snoopy's files tonight.
The timescale is modified via the iTurnsPerMonth entry in the scenario XML.
tomasvicente38
Post
by tomasvicente38 » Wed May 09, 2007 12:39 pm
I put the screen to you of the victory.
- Difficult financier
- RailRoads 2007-05-09 14-26-18-37.jpg (533.48 KiB) Viewed 12091 times
tomasvicente38
Post
by tomasvicente38 » Mon May 14, 2007 7:27 pm
I have modified the map as far as the goods and the production of passengers.
In order to install it is necessary it to extract it in Custom Assets.
The file new this the first message.
tomasvicente38
Post
by tomasvicente38 » Mon May 14, 2007 8:02 pm
Somebody knows like putting a port in Valencia and a power station of containers in some zone of the map?
Targa
Post
by Targa » Thu Jun 07, 2007 3:48 am
Stretch time by adding the following to your Scenario xml:
<iTurnsPerMonth>(number)</iTurnsPerMonth>
Place a (number) between there to make time last longer. 2-digit numbers around 20-25 make the game time pass fairly slowly.
Post
by snoopy55 » Thu Jun 07, 2007 4:17 pm
Tomas - your requset for port can be done.
can you please use spanish to ask about container part as I don't understand power station part.
thanks
Post
by snoopy55 » Tue Jul 03, 2007 4:54 am
to repeat -
tomasvicente38 wrote:Somebody knows like putting a port in Valencia and a power station of containers in some zone of the map?
thanks
Post
by Warll » Tue Jul 03, 2007 5:07 am
Since he asked about putting the "power station" somewhere else I qould think it is safe to say he is asking for a depot. Although who knows.
keotaman
Post
by keotaman » Tue Jul 03, 2007 9:37 am
I suspect that he means a port as in
shipping port, and a (power) station of containers as in
Container Terminal, a place for loading & unloading containers from ships.
Post
by Warll » Tue Jul 03, 2007 1:11 pm
keotaman wrote:tomasvicente38 wrote:Somebody knows like putting a port in Valencia and a power station of containers in some zone of the map?
Can't be because how could you have the port in Valencia then have the Terminal "in some zone of the map"?
Post
by snoopy55 » Tue Jul 03, 2007 4:03 pm
Ports could be put in Valencia and Cullera. The word "zone" could have been translated from a word also meaning "area". A terminal could be put somewhere in the western part of the map. As to what is shipped there and whether a single container type is used as in Basin and Range or multiple as in Side to Side is another question. If someone wants to research it from what the map contains, I or another could possibly work on the programming.
drsnooker
Post
by drsnooker » Thu Jul 05, 2007 1:45 am
Looks like fun, but still trying to figure out how to get beer.... I can't build a brewery (it's not in the list of available industries) nor is there one anywhere on the map.
It'd be nice to have an oil field somewhere too
Did I get an old version of the setup file?
Thanks!
Post
by snoopy55 » Thu Jul 05, 2007 2:45 am
The talk done about a Port and Dist. Point are mute as Tomas has already created one.
The Oil is on an island. Click on Oil in the list and it will show up at the lower left corner of the Station Button. As to the Beer, it falls right in with a few other things that need refining. I'll look into it as I research this and other maps.
Post
by Slappy Da Clown » Thu Jul 05, 2007 9:48 am
See the following post
http://hookedforums.com/a/viewtopic.php?p=17382#17382
and the one after it for beer fix. You already fixed this problem Snoopy.
Dell Dimension 8400
3GB Memory
