Alaska
thegrindre
Post by thegrindre » Wed Jan 10, 2007 6:39 pm
WOW!!! Great map, man. Thanks for all the hard work you've done on this. Koodoos to you. :D
Kroguys
Post by Kroguys » Thu Jan 11, 2007 4:16 am
Thanks for a nice map. I tried it online with 3 other people. Was the only one fishing, made enough money with food to buy out one player which lead to a win for me. :wink: I like how big the map is and how far cities and resources are. This is what railroads are all about.
TheAlmightyBenwa
Post by TheAlmightyBenwa » Thu Jan 11, 2007 7:12 am
Thanks for your hard work on making an awesome map for all of us to download and use.
Top stuff Mate!
Yes im an Aussie, haha
TheProgrammingGuy
Post by TheProgrammingGuy » Thu Jan 11, 2007 4:37 pm
I must agree, this is an awesome map. I set the ITurnPerMonth to 64 so I could play it out 8)
Unfortunately, it appears I've hit a dead end. From my last save, the game will always crash at February 27, 1939. Not sure if it's to do with the map, something funky because of the time-scaling, or just my PC. I was having so much fun, too. :cry:
Orange46
Post by Orange46 » Fri Jan 19, 2007 9:37 pm
I downloaded Alaska and I thought I put it where it was supposed to go, but it didn't come up in the game. Then I looked at the other files where I placed it and none of them were .rar files. In the scenario folder, there aren't any .rar files either. Help.
Kenster
Post by Kenster » Fri Jan 19, 2007 9:57 pm
You will need to get WinRAR and unzip it. Then place it in your folder.
WinRAR has a 40 day trial. You can Google it.
Ken
PS Good point though. I guess we should all zip it into a .zip file so windows can unzip it.
Post by snoopy55 » Sat Jan 20, 2007 3:35 am
Forget the trial versions... go to this address:
http://www.7-zip.org/
It's free and works on many, if not all, zip files.
Kenster
Post by Kenster » Sat Jan 20, 2007 4:56 pm
Cool Snoopy..
I'll have to give it a try..
Thanks for the info.
Ken
Post by snoopy55 » Tue Feb 13, 2007 11:31 pm
Dayrl - I was going thru maps and stripping out material that is supplied by the Global XML files and when I played this one, I noticed the first engine, the Amaerican, didn't have a tender. Thinking I may have messed that up when I first played with it I downloaded a fresh copy. You only have 4 of the 8 tenders in RRT_TrainCars_ALASKA.xml. Was this intentional?
Post by atani » Tue Mar 06, 2007 6:10 am
attached is an installer for this map.
Setup_ALASKA_1.0.zip
(353.44 KiB) Downloaded 1856 times
good one
Post by Slappy Da Clown » Sat Apr 07, 2007 12:56 pm
Very nice map. Put on with installer. Smotth play for a while then I saved it & quit. Came back & loaded it later to sever CTDs. Finally it played through to the end. Im working on a theory about the CTDs, it may or may not be the map. I think it may have something to do with events but it seems to be random.
So for now while I do more investigating call this a very nice map. A good historical scenario could be put together from here
http://www.alaskarailroad.com/arrc119.html
Im sure if someone was in the mood.
Dell Dimension 8400
3GB Memory
CeeBee51
Re: good one
Post by CeeBee51 » Sat Apr 07, 2007 6:09 pm
Slappy Da Clown wrote:Very nice map. Put on with installer. Smotth play for a while then I saved it & quit. Came back & loaded it later to sever CTDs. Finally it played through to the end. Im working on a theory about the CTDs, it may or may not be the map. I think it may have something to do with events but it seems to be random.
I have seemingly random CTD's in probably half the maps I play. Sometimes a map will play full through but most of the time I get a CTD though usually I can reload from the last save and keep on going. The weirdest CTD's I get is when I retire from a map which happens about half the time and not on all maps. Freakin buggy something or other though I don't wanna hurt anyone's feelings by calling the game buggy :? :shock: :D
Post by snoopy55 » Sat Apr 07, 2007 6:27 pm
Slappy, CeeBee - write down the Events and then check each off as they happen and when it CTD, look at what has not happened. If it is an Event, it should narrow it down.
new thread
Post by Slappy Da Clown » Sat Apr 07, 2007 11:57 pm
Im gonna start a new thread about these CTDs in Mods-Talk so this map thread dont get hijacked.
Dell Dimension 8400
3GB Memory
Post by K-class » Sun Apr 08, 2007 3:44 am
One large map with lots of towns / cities and lots of resources.
Only change I did to this map was replace the trains.xml with my own with all the diesel electrics.
I experienced to major CTD's with this map that caused my pc to drop to the lowest display setting. Took a reboot to restore the correct display. I only run at 1024 x 769 on a 19 inch monitor.
One happened Fairbanks Colliery and at Dawson Ukon, I did not notice anything apart from when Ii reloaded the map there where a few auction events.
I was at year march 1908
After a reboot I was able to carry on playing my saved game. Has not crashed again. fingers crossed.
This is a great map for the AC 4400 dual as lots of long runs.
I only installed my graphics card yesterday and are on my 3rd lot of drivers for it.
Looks if it just has a lot going on for this map?
I will add to Slappy Da Clown post. http://www.hookedgamers.com/forums/view ... 6262#16262
