This is last update for Rodea Bank, wich Rodea Bank now having 3 Levels that are Level 1 (small size), Level 2 (medium size) and Level 3 ( Large size ).
Download the zip file and read instruction below:
Zip file provided 1 xml file(Rodea_Bank.xml) and 1 folder (Rodea Bank), after extracted copy Rodea Bank Folder to your CustomAssets Folder and add all Rodea_Bank.xml contents into RRT_Industries_yourmap.xml ( you can change input and output for the Rodea Bank as you want)
Rodea Mods : Rodea Bank
- Rodea Bank.zip
- (712.08 KiB) Downloaded 503 times
Re: Rodea Mods : Rodea Bank
Hi Rodea!
Can you make the terrain trasparent or make it disappear?
It clashes with the surroundings.
Here Rodea Bank after edited, download and extract the zip file into your computer then copy Rodea_Bank2.nif file to Rodea Bank folder under CustomAssets folder, when you get message to overwrite Rodea_Bank2.nif click yes, now you have Rodea Bank Model without basement, notice to the picture belowJancsika wrote:Hi Rodea!
- Rodea_Bank2.zip
- (31.33 KiB) Downloaded 447 times
