Bay Area, California WIP
omega552003
Post by omega552003 » Tue Nov 28, 2006 6:36 am
Completed:
Height map
water level
general terran color
Custom DIR layout
minimap
Still to fix/do:
Im having a little issue with water color, its red/pink.
City placement & naming
Resourcing load out
resourcing need
map message
Senario conditions
Post by snoopy55 » Tue Nov 28, 2006 7:32 am
I've read in a couple places in the map section that it has to do with 48 as the depth.... Read thru them and it may help.
omega552003
Post by omega552003 » Tue Nov 28, 2006 12:51 pm
i got that far and the water level is perfect, its just the color that is off.
d53642
Post by d53642 » Tue Nov 28, 2006 2:07 pm
What program are you using and did you modify the water box any?
omega552003
Post by omega552003 » Wed Nov 29, 2006 12:00 am
d53642 wrote:What program are you using and did you modify the water box any?
Photoshop CS2(9)
no i didn't
eilelwen
Post by eilelwen » Wed Nov 29, 2006 12:51 am
ohhh, now I'll need to make some trollys :), eventually.
d53642
Post by d53642 » Wed Nov 29, 2006 4:12 am
Another thing I noticed why is your map 512x512. In printshow the maps show as 601x601, would the size not be the same for photoshop?
Daryl
omega552003
Post by omega552003 » Wed Nov 29, 2006 4:12 am
eilelwen wrote:ohhh, now I'll need to make some trollys :), eventually.
the B.A.R.T. and A.C.E. trains would be cool too,
d53642
Post by d53642 » Wed Nov 29, 2006 4:14 am
Also if you could post a screenie of your map with all 7 parts or so it might be easier to tell you what could be wrong.
omega552003
Post by omega552003 » Wed Nov 29, 2006 4:14 am
d53642 wrote:Another thing I noticed why is your map 512x512. In printshow the maps show as 601x601, would the size not be the same for photoshop?
Daryl
thats the minimap, my standard map is 601x601
omega552003
Post by omega552003 » Wed Nov 29, 2006 4:17 am
PMed you the image
d53642
Post by d53642 » Wed Nov 29, 2006 4:24 am
Your second image water area doesn't look right. Might be why your water is pink. I'll pm you a message shortly.
omega552003
Post by omega552003 » Wed Nov 29, 2006 6:50 am
Figured it out.
in my maps senario xml this value was set wrong:
<szDeepWaterColor>210,90,0</szDeepWaterColor>
that displays an orange
so i reversed it (R,G,B)
and got a nice blue
<szDeepWaterColor>0,90,210</szDeepWaterColor>
Post by atani » Sat Mar 10, 2007 3:10 pm
Whatever happened to this map?
Did omega fall off the map?
omega552003
Post by omega552003 » Sat Mar 10, 2007 4:28 pm
no it went into my backlog of stuff to do , ill see about finishing it soon
