TGV Carriage with Door Animation
This is good news, TGV Passenger Car now have door animation, that mean the door will opened when not have passenger (empty passenger) and will closed when the wagon full load with passenger
please look at to the picture below.
How to use : download then ectraxt the zip file below into CustomAsset folder then play the map with have TGV train ( France Map ), so you can see how is it work
- TGV_Door Animation.zip
- (43.99 KiB) Downloaded 506 times
Re: TGV Carriage with Door Animation
The bad new is It does not work just tested and nothing happened at all.Rodea2007 wrote:This is good news, TGV Passenger Car now have door animation, that mean the door will opened when not have passenger (empty passenger) and will closed when the wagon full load with passenger
No door movement at all empty or full.
As you can see in the screenshot 1st 2 carriages are full and the last 6 are empty.
Bobby's Sid Meier's Railroads Forums and Bobby's Sid Meier's Railroads Wiki
:: The Only Working & Up to date Wiki Now ::
You should be use passenger_car_tgv.nif and passenger_car_tgv.kfm from the downloaded, as my instruction download then ectraxt the ZIP/7ZIP file into CustomAsset folder then try to play the map wich provide TGV Train that is France Map, did you followed my Instruction?, because I saw in your picture that is not model from my upload file, if you use the original or reskin from TGV model that model can't work because those upload model has been edited with 3ds max with added bone b_Door as skin instance for door animation, if you did not follow my instruction don't set me up......vzbob wrote:The bad new is It does not work just tested and nothing happened at all.Rodea2007 wrote:This is good news, TGV Passenger Car now have door animation, that mean the door will opened when not have passenger (empty passenger) and will closed when the wagon full load with passenger
I just download that file then extract to CustomAsset folder and then play France Map, so you can see on the picture below that model can be working if you follow my instruction, so I remember what happen when I post an SAM Map with installer because you did not to do what I said so you blame me out with what happened to you........that is not good friend....
Don't worry if you got CTD when play the mod to the first, please restart your map because the game need adjust to use a new model
Rodea2007 wrote:You should be use passenger_car_tgv.nif and passenger_car_tgv.kfm from the downloaded, as my instruction download then ectraxt the ZIP/7ZIP file into CustomAsset folder then try to play the map wich provide TGV Train that is France Map, did you followed my Instruction?, because I saw in your picture that is not model from my upload file, if you use the original or reskin from TGV model that model can't work because those upload model has been edited with 3ds max with added bone b_Door as skin instance for door animation, if you did not follow my instruction don't set me up......vzbob wrote:The bad new is It does not work just tested and nothing happened at all.Rodea2007 wrote:This is good news, TGV Passenger Car now have door animation, that mean the door will opened when not have passenger (empty passenger) and will closed when the wagon full load with passenger
I just download that file then extract to CustomAsset folder and then play France Map, so you can see on the picture below that model can be working if you follow my instruction, so I remember what happen when I post an SAM Map with installer because you did not to do what I said so you blame me out with what happened to you........that is not good friend.......So I suggest to you to always following the instruction if you won't to make an mistake.
It is no mistake my friend
And it should not matter where you place the files whether they are in the CustomAssest Or Usermaps folder they should work anywhere.
It is your model installed the only difference is the DDS files for the TGV have been recolored for my map and it is not a setup as you call it. It just did not work for me.
And I also remember
So don't try to shift the Blame onto me.
I just play Bobby Map The Australia Gold, notice to the picture below .....the mod is working fine, but need a little change to make it work.......How is it working?, please find out by your self, but if you couldn't let me know I will teach you
Notes....If you use original XML for TrainCars you not need to make any changed, just extract that zip file into CustomAsset folder then play France Map, In this cause Bobby use "AU Passenger Car" name as passenger car name that it is not default name, so he need a little change to make this mod can be working as I have been done with his map
The TGV Train Is The Games Standard Train and traincar and Uses the standard full listed RRT_Trains.XML text for the TGV train.Rodea2007 wrote:I just play Bobby Map The Australia Gold, notice to the picture below .....the mod is working fine, but need a little change to make it work.......How is it working?, please find out by your self, but if you couldn't let me know I will teach you
I still can not even get it to work on any standard map that uses the TGV train on a clean set of folders with no other maps installed anywhere and as we are not mind reader why don't you post what you changed so we all can see it as well.
I don't now what happen by your machine, but I was tested with make clean Install ( do not have any map in UserMap folder) then extract the mod into CustomAssets Folder after that France Map was played, that is all the mod working fine as you seen in the picture above, but for your Australia Gold map I need make a little change because you use not default names for train cars especially for passenger car you use name "au_Passenger_Car.kfm" for KFM file so I must change the KFM name from the mod to au_passenger_car_tgv.kfm, that is all this mod can run fine, don't forget to put this mod in your CustomAssets Folder ( all files as you downloaded ) and be better if you rename the old au_Passenger_Car.kfm in warehouse foldervzbob wrote:The TGV Train Is The Games Standard Train and traincar and Uses the standard full listed RRT_Trains.XML text for the TGV train.Rodea2007 wrote:I just play Bobby Map The Australia Gold, notice to the picture below .....the mod is working fine, but need a little change to make it work.......How is it working?, please find out by your self, but if you couldn't let me know I will teach you
