Hy everybody, basically thanks to let me jin this amazing foryùu,.
i still have problem to put your wonderful maps in my railroad games. that's why i m requesting a help to some italin users, to help me in the stepping to change setup and all the stuff.
maurizio
-----italian version*--
ragazzi italaini sul forum per favore aiutatemi a installare le mappe sul mio railroadm io provo a seguire le regole in inglese ma un ci riesco mica.
grazie
Maurizio
Rq. Italian instructions for change the maps on Railroad
Re: Rq. Italian instructions for change the maps on Railroad
Well maurizio welcome to the forum.
I am not sure if we have anyone who speaks Italian. The new style maps are made as self-contained maps. They "should" have everything they need to run by themselves. There is still a couple who are making the old style global maps where you have to have certain maps, fpks and the kitchen sink in order to run...very confusing.
The new self contained maps are stand alone. They are placed in the UserMaps folder by themselves.
This requires that the files for RailRoads in the MyGames section of the game must be clean of all other maps and fpks. Nothing can be inside the CustomAssets folder.
The SAM or CIC or self-contained map files are the only map that gets placed in the usermaps folder. When you are done playing that self-contained map, remove it from the usermaps folder, then place the next self-contained map in the usermaps folder and play away.
The new self-contained map system keeps the game from getting overloaded and crashing. Large maps and maps that have much custom made content run fast and smooth this way. Each self-contained map thread, should have some instructions as to how to load and play.
http://translate.google.com/
Bene Maurizio benvenuto al forum.
Non so se abbiamo qualcuno che parla italiano. Il nuovo stile mappe sono fatte sotto forma di "self-contained mappe. Essi "devono" avere tutto ciò di cui hanno bisogno per funzionare da soli. C'è ancora un paio che stanno facendo il vecchio stile globale mappe dove è necessario disporre di alcune mappe, fpks e il lavello per eseguire ... molto confusa.
Le nuove mappe sono contenute autonomo stand-alone. Essi sono collocati nella cartella UserMaps da soli.
Ciò richiede che i file per Ferrovie in MyGames sezione del gioco deve essere pulita di tutte le altre carte e fpks. Nulla può essere all'interno della cartella CustomAssets.
La SAM o CIC o self-contained mappa file sono l'unica mappa che viene inserito nella cartella usermaps. Quando si è finito di giocare che self-contained mappa, rimuoverlo dal usermaps cartella, quindi luogo il prossimo "self-contained mappa nella cartella e riprodurre usermaps distanza.
La nuova "self-contained mappa mantiene il sistema di gioco da sempre sovraccarico e danneggiamento. Grande mappe e cartine che sono molto più contenuti personalizzati correre veloce e corretto in questo modo. Ogni "self-contained mappa thread, dovrebbe avere alcune istruzioni su come caricare e giocare.
Use the Google translator!!!
Il seguente è le istruzioni per l'uso SAM/SAM2 CIC.maurizio wrote:Hy everybody, basically thanks to let me jin this amazing foryùu,.
maurizio
grazie
Maurizio
1) Andate in C: \ Documents and Settings \ (il tuo nome computer) \ Documenti \ Giochi e rinominare il Sid Meier's Railroads! cartella che si hanno attualmente, aggiungendo ad essa una fine, quello che volete.
2) Avviare il gioco. Quando si arriva al menu principale, uscita.
3) Vai in Sid Meier's Railroads! rinominato cartella e copiare i 'Settings.ini' in atto la nuova Sid Meier's Railroads! cartella. Avete ora la base per tutte le future SAM CIC e mappe.
4) Aprire il Sid Meier's Railroads! cartella, quindi aprire la cartella UserMaps.
5) Aprire il file Zip del Map si desidera riprodurre e di estrarre l'intero contenuto UserMaps alla cartella.
6) Chiudere tutte le cartelle e giocare la carta.
Per riprodurre una mappa diversa:
1) Aprire il Sid Meier's Railroads! cartella, quindi aprire la cartella UserMaps.
2) Eliminare tutte le cartelle ei file contenuti lì.
3) Aprire il file Zip della mappa che si desidera riprodurre e di estrarre l'intero contenuto di UserMaps la cartella.
4) Chiudere tutte le cartelle e giocare la carta.
Ora, alcuni di voi ritengono che il deposito / FPK cartelle devono essere in CustomAssets. Questo è bene con noi, non come lo si desidera. È necessario ricordarsi di eliminare quelli di magazzino / FPKs da lì quando si cambia mappe. Per la maggior parte, lasciando loro non dovrebbe creare problemi, ma poi non abbiamo alcuna intenzione di attenersi ogni magazzino / FPK file in CustomAssets e test. Non è come per le precedenti istruzioni e non dovresti avere problemi. Se si è scelto di svolgere un CIC stile mappa, seguire le istruzioni fornite con quelli.
Bobby's Sid Meier's Railroads Forums and Bobby's Sid Meier's Railroads Wiki
:: The Only Working & Up to date Wiki Now ::
