Terrain Editor Conflict?
I place this question in this thread, if not the right place just let me know.
I have installed several scenarios, starting with the new Santa, Chicago.., Arizona, Styx, Basin etc….
They all worked fine when I was playing them.
But then I discovered, that in the Terrain Editor I could not “Create a New Mapâ€
- stormfather
Terrain editor conflict?
One more thing.
I went back and uninstalled the scenario
including the .FPK file, but the editor conflict remained.
JB.
JB.
- stormfather
- stormfather
I believe this is a problem with the Globals like stormfather said. I have had it happen to me on several occasions. When you create a map in the Terrain Editor I think it tries to make all content in the Global XMLs available to you and if something is not quite right it will crash. What I usually do is MOVE my CustomAssets folder to my desktop and start putting things back one at a time or in small groups like all the FPKs. It usually comes down to something in one of the XMLs. So to start maybe just move the XML folder to the desktop and see if you can create a new map.
I just did my Central Mexico map and found one nasty problem. When it creates the XMLs it uses 3 from the NewMapBase folder, Cities, Goods and Industries. When it comes to TrainCars and Trains, it pulls what it needs from GLOBALS, which is everything, including Tenders. So while it loades fine in Editing, when it's loaded in Scenarios, CTD. Remove what it doesn't use in Cars and wipe Tanders, and it's fine. Maybe a tryout on editing the NewMapBase files to add TrainCars and see what it does. I may mess with that.
I've noticed that too.
New maps pulling in everything from Trains and TrainCars global. So I create new maps, shut down the game, edit all xmls, then return and add whatever to the map, Then go back and edit the xmls a bit more...all before play testing.
EDIT//That's what I have made up also choobacca, any new maps just get the "starter pack" I call it. It's not too big a deal, but you better remember to edit it...the christmas engine pulls the most errors if you don't change the trains list, so if you get that error it's a good reminder that you forgot to edit the trains list...
Big Papa and I have also seen this problem but didn't know what caused it. So to make starting maps more convenient, I have created templates that we load whenever we want to start a new map. These templates include the starting map and the xml for all Goods, Industries, TrainCars, and Trains. So now I am making them available for you!
The attached ZIP file contains a map directory for each of the standard map sizes, and a small utility program I wrote inside each directory that creates a clone of the scenario with the name you specify.
Using these saves you the first couple steps of creating a new map in the editor, exiting, editing XMLs to include all industries, then relaunching the editor.
Using the cloning utility programs, you can quickly create as many maps as you want with the click of a single button!
- TemplateMaps.zip
- Template maps for all standard map sizes
- (331.35 KiB) Downloaded 343 times
Sounds great! Just to update my experiment, I put my stripped XML, Goods, Indusrties, TrainCars, Depots and Cities. Then Edited the Blank Scenario for those. I got to choose what I wanted from a full list, but it still extracted all the tenders from the GLOBAL and added them.
So, I guess I check out this new ZIP. You would wait till I fought for 6 hours with the Central Mexico map.... saves Cities and Industries fine, but likes to CTD right after saving the map.
