![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
First a question. Have any of you had a map that was working, maybe one you played a while ago and for old time sake of some other reason you tried to play it again and it did nothing but CTD?
Well, that's what has happened to me, at least as far as I can tell. The map is my BC Gold map and it worked just fine though I hadn't played it in a month or more as I had a modern version I was fooling around with plus all the other maps that were coming online like the Arizona map, Basins & Ranges, etc. Well, over Easter I decided to play the BC Gold map and it did nothing but CTD. Usually just after I had built a couple of stations and got a train or 2 purchased and started. I went through the xml's that I thought could be the problem.... the traincar.xml, trains.xml and the scenerio xml. I even went through the events.xml and removed all the stuff that wasnt needed but nothing helped. Well, finally I got fed up and decidied since the Modern version I have was working, and since the only difference was the scenerio and the trains xml's that I would try and replace one xml at a time, load SMR and try to run the BC gold map. Well, on a whim I tried the goods.xml first, mostly because the CTD's seemed to happen as soon as a train started loading. Surprise , surprise, BC Gold worked as soon as I swapped the goods xml file so I closed things out and opened both files in notepad++. As far as I can see there is nothing different between the files other than some of the formatting in the file that didn't work was different. There were no errors in the code but just some spaces which caused the <goods> or </goods> to not line up withe each other as I scrolled down through the file. Now IMO that really shouldn't make a difference but I'm certainly no expert. What I'm wondering is how the file that quit working got buggered up as I have not opened or edited either file since I copied them to create the new version of the map. Both worked just fine for a long time after anyway so what the heck caused the changes to one. It was the least used and had not caused any problems in the past that I recall. Does a game CTD with one map running cause a problem in some other maps xml on occasion? Am I imagining things or is this just another goofy goofup like the blue smurfy engine problem that I and a few others have? Anybody have any ideas?
