Ermel
Post
by Ermel » Fri Mar 16, 2007 10:23 am
I´m currently building a scenario and want a certain city to be the only possible start location. I hooked "start location" at that city and saved it. XML file says:
<bIsStartLocation>true</bIsStartLocation>
for that city and
<bIsStartLocation>false</bIsStartLocation>
for all the others.
but in spite of everything the start location is put randomly every time i play the scenario. though i play without AI opponents.
how can i make sure that there´s only the start location i chose?
must I choose a minimum number of start location? like four maybe? so that every potential player has his own start location?
Post
by snoopy55 » Fri Mar 16, 2007 2:33 pm
From experiance of tryingto do the same thing alot, 'dar ain't no way'. It seems to be hard wired into the game that if it doesn't get a certain number, 4 I believe, tho it may accept 2 or 3, it puts them where it wants to.
Now, can you do a little research and see if it will accept 2 or 3? You have the map and the need, and the Wiki needs the answer.
Pretty Please....with a 2_8_2_Mikado on top...... I'll even throw in a tender........
Ermel
Post
by Ermel » Sat Mar 17, 2007 1:43 pm
thank you, snoop!
that´s what i guessed, but for it´s my first scenario, there´re so many things i´m testing, such as victory conditions, changing in- and outputs of industries, advancing the map and so on, that i put back this issue.
anyway it might be a good idea to do it first, because it´s quite annoying to be spawned in the middle of the outback every time, if adelaide is the place i want to start at.
Ermel
Post
by Ermel » Sat Mar 17, 2007 8:04 pm
Ok, I´ve got it!
It´s got to be at least 4 start locations! no less.
Post
by snoopy55 » Sat Mar 17, 2007 9:59 pm
Thank-you my man.....1 test down, 999,999 to go
That sounds like info for Wiki.
As you build that map, work out one thing at a time, otherwise it is difficult to find what went wrong.
