Quad City Lake in Winter Season by Rodea2007
Post by Rodea2007 » Mon Jun 30, 2008 5:59 am
This map I release to answer my question that is possible to change trees in Ohio in Holiday map by Lowell with snow effect. Those trees this map is clutter not Decoration. only need a little work to changed it. That's simple way to use this map, extract rar file into UserMaps Folder then you can play this map.
The base map is original map MP_06 only edited Terrain and Clutter with adding snow
Enjoy with it.... :P
Re: Quad City Lake in Winter Seasion by Rodea2007
Post by K-class » Mon Jun 30, 2008 7:22 am
Hello how and what did you do, was it just xml file edit. I could rip the downlaod map apart but please explain.
Post by Rodea2007 » Mon Jun 30, 2008 8:18 am
K-class wrote:Hello how and what did you do, was it just xml file edit. I could rip the downlaod map apart but please explain.
Just simple away, only edit RRT_Clutters_yourmap.xml and recolor what dds file needed, that is provided in rar file
Post by K-class » Mon Jun 30, 2008 8:48 am
you sure you dont work for 2k / Firaxis Games as with this and the terminal fix these are nice tweaks that make the game more enjoyable. Thanks heaps. Im sure lowell can put these into his maps.
Can you work on the quadwrangle neing black please as it will now disapear completetly. :D
Post by K-class » Mon Jun 30, 2008 9:27 am
Hello Rodea2007 I suppose the next step is to add snow to all the default buildings. like grain and timber etc.
I think lowell has painted snow on some of his in the Holidays_In_Ohio-ToyTrains CIC v2.0 see pic
PS I add your fix to lowells map to see what it looked like as well.
mikeyc
Post by mikeyc » Mon Jun 30, 2008 9:28 am
Very clever Rodea. Not only does it look really good it also makes you feel cooolllllddd.
I think the forum will have to appoint you as chief of map scenery development.
Terima Kasih Banyak
After posting this comment I went back to playing the game and as I moved around the map I noticed some things that are worth pointing out for your enjoyment. Before you start the map put your shadows on high and tree density high, then scroll around and have a look.
Notice how there is no water movement in the rivers in that they actually look frozen. Also notice how the snow is not consistently thick in that it looks windswept particularly on the bare hills, creating a dazzling effect.
This is a work of art.
Post by dwax » Mon Jun 30, 2008 3:26 pm
Do you need the base map to play this? And what and where is the base map?
Post by K-class » Mon Jun 30, 2008 6:21 pm
hello dwax
Its all there this is like a SAM - CIC map just unrar and shove into your maps folder. Remove any other maps in there.
You dont need SMRI or anything else. I havnt played it but it starts up and was able to lay track without a ctd so the this map should run as it has all the standard game industries etc. (apart from the snow etc.)
Post by Lowell » Mon Jun 30, 2008 7:18 pm
We all have been trying to add new trees in the clutter menu and have not had sucess with adding new trees to the game. Have you made a "new" tree with a "new" clutter number...or have you overwritten an in-game tree? I am going to download your map and see.
I am working on an update for that map set, I had painted some trees already, but I was trying to add them as new trees for the editor and it wouldn't take my number change/addition. I forgot about the map being a CIC map, maybe I can let the game overwrite the trees DDS for just that map only, then I don't have to make a new tree, just temporally overwrite the trees DDS file.
"I had thought of painting white on the games default industries, but there is only so many days you can live in PhotoShop before you get totally bored..." :D but the new update will have several new addons added to the map.
That is an interesting "green" color added to the landscape, but I have never seen green in snow, maybe a tiny bit of blue, and on nights where the ground is covered with deep snow and a full moon...it has a blueish tone to it. :)
EDIT// Okay I see what you have done. This will work fine as long as you have a CIC or self contained style map as it overwrites the games dds file for those trees. I still haven't found that mini map game triangle...I looked everywhere. I might be able to do something like this and get the palm, orange and lime trees in the F/G map...I am going to try some experiments, it looks like this might just work...thanks.
Post by karsten » Mon Jun 30, 2008 10:19 pm
:shock: Very clever idea, Rodea - well done, once again! Had to try out the effect immediately, looks great! :P
Lowell, the green hue you mention is visible in the distance on the lake border in my first and especially in the last screenshot. I fixed that with brute force - I repainted the tga.map white, took me 30 seconds and that certainly bleached the snow, as you can see in the middle two pictures. :mrgreen:
Post by Burlington_Northern_3140 » Mon Jun 30, 2008 11:24 pm
I can help with the painting of the industries. Here is the coal plant. Just needs Renaming and to be Packed as a FPK.
BB_Coal_Power_Plant3.zip
(2.29 MiB) Downloaded 487 times
Post by Lowell » Mon Jun 30, 2008 11:42 pm
Oh cool...I am working on a update for my holiday map, I can use those too. No need for the fpk...just need the dds file, then I can rename and rebuild it as a new model.
Post by Burlington_Northern_3140 » Mon Jun 30, 2008 11:52 pm
You could use this too.
Pine snow.zip
(62.62 KiB) Downloaded 439 times
Christmas Pine.zip
(67.47 KiB) Downloaded 401 times
Post by Lowell » Mon Jun 30, 2008 11:58 pm
...this is awesome thanks...I need the coal mine, factory building, sheep farm, dairy farm, this is funny because just the other night I was looking into making a set of US city buildings and houses for winter snow.
Post by Burlington_Northern_3140 » Tue Jul 01, 2008 12:04 am
Lowell wrote:...this is awesome thanks...I need the coal mine, factory building, sheep farm, dairy farm, this is funny because just the other night I was looking into making a set of US city buildings and houses for winter snow.
:idea: This could be an interesting project. I will try repaint all of the houses, industries, trees and buildings for winter, fall and summer.
