Europa
tomasvicente38
Europa
Post by tomasvicente38 » Tue Apr 03, 2007 9:43 am
Map of Europe. Map size 20.
Europa.zip
History of the European Union.
(627.81 KiB) Downloaded 995 times
Last edited by tomasvicente38 on Tue Apr 03, 2007 7:07 pm, edited 1 time in total.
Post by snoopy55 » Wed Apr 04, 2007 9:40 pm
Dr Frag - you can also go into the map editer and go to "Start a new map from a scenario map". Choose Europa, edit it and save it. Then just open the maps folder and replace the TGS and DDS with the ones from the UserMaps. I've done this several times.
tomasvicente38
Post by tomasvicente38 » Wed Apr 04, 2007 10:51 pm
The one to replace archives TGS and DDS not since to do it me you can explain in detail. Thanks.
Post by atani » Thu Apr 05, 2007 5:17 am
snoopy55 wrote:tomasvicente38 - I'm working on the translation......
Once you have the translations done I will package the installer for this map.
Post by snoopy55 » Thu Apr 05, 2007 6:29 am
OK, I think I have it. There may be some wrong or bad translations. If you find any, post it. I had trouble figuring out Le Monde until a last search showed it to be the name of a French newspaper :roll: . A few misspellings on Tomas's part made it a little rough. :?
Take it away atani.......
Europa Scenario in English.zip
(3.35 KiB) Downloaded 462 times
Post by atani » Thu Apr 05, 2007 2:24 pm
Installer attached for spanish and english versions of this map.
The english version does not include translated town names (Snoopy, if you send me a copy of the Cities file translated I will include it)
Setup_Europa_1.0.zip
(441.71 KiB) Downloaded 1308 times
Post by snoopy55 » Mon May 07, 2007 2:43 am
Sorry Atani, things have been confusing this last month. Here are the Names trans and a correction in the Scenario.
Europa_name_change.zip
(3.96 KiB) Downloaded 433 times
Post by snoopy55 » Mon May 07, 2007 8:04 pm
I didn't mess with the locations, I just did Spanish to English translations in RRT_Names and in the Scenario I translated the Spanish for European. There are 31 cities. A list of them is attached, check it out for us. :twisted:
31 Europa names.rtf
(556 Bytes) Downloaded 410 times
