I just got out of a game where i obviously did not understand what was happening.
Is it possible to purchase stock when your in debt? My opponent had about 1.5 million dollars in debt and continued to buy stock (one once in a while), with an annual profit of negative 63,000. I dont understand how he did ths?
How in the world did he do this?
Re: How in the world did he do this?
It was either a glitch or a cheat.
Assuming your opponent was an AI you can expect this to happen from time to time. The one map that I remember it happening was Amerigonia. There is nothing you can do about it. Let the AI do his thing and you buy him out as soon as you can and then you will get all those good assets. It appears the AI cant cope with involved processes but they do learn. If you play the map a few times you will find that they dont make the same mistakes nor do they get incredible loans and so becomes more 'normal'.
- darthdroid
Linus wrote:I just got out of a game where i obviously did not understand what was happening.
It is most likely Linus that you were simply "out of sync" with your opponent. On his/her screen, it probably also said YOU were heavily in debt. This happens quite a bit, especially if you're on the other side of the world or opponent has a glitchy connection from my experience.
However, it is possible it was a cheat. If someone uses a trainer program, you'll see the same thing. But you also still see an "out of sync" message. It is also true that usually it shows a debt in the millions, not thousands. If the financial screen was the only indication of strangeness, it is unlikely a cheat but rather just a glitch.
-Bob the Lunatic
