Lowell wrote:Making sure the light towers are set right is the key for the trains to follow the traffic pattern
This kind of implies that it's possible to adjust or influence the way sign posts work,
while I believe you are simply refering to the positions where you hook the track up
to another track. Is that correct?
The fact that the game can only handle a single switch is one of the most
dissapointing
factors to me because it prevents us from laying 'real' tracks.
If you try to construct the three-point switch that you need, you end up with
two sign-posts
directly following eachother.
And THAT's where trains go wrong and stand still budding heads.
Really annoying.
(Other than that, addictive stuff)
