Trains in America
VirginiaAndTruckee
Trains in America
Post by VirginiaAndTruckee » Fri Jun 17, 2011 6:42 pm
All of the European trains are available to me in American scenarios, as well as the trains that should be there. How do I fix this?
Re: Trains in America
Post by karsten » Fri Jun 17, 2011 7:45 pm
The short answer is to delete the unwanted engines from the XML. Does that help? :P
Post by snoopy55 » Fri Jun 17, 2011 11:27 pm
All the US maps use the same engines from the US East.
Open My Games\Sid Meier's Railroads!\CustomAssets\XML\_SCENARIOS_\US_East and place the attached modified XML into it. The game will use it in place of the original one since it has a newer datecode.
RRT_Trains_US_East.7z
(429 Bytes) Downloaded 446 times
VirginiaAndTruckee
Post by VirginiaAndTruckee » Sat Jun 18, 2011 2:24 am
snoopy55 wrote:All the US maps use the same engines from the US East.
I know this, but for some reason the European trains are available in America. They're NOT in the RRT_Trains_US_East.xml or in the US East folder at all, but they still show up.
BTW the file didn't help.
Last edited by VirginiaAndTruckee on Sat Jun 18, 2011 2:31 am, edited 2 times in total.
VirginiaAndTruckee
Post by VirginiaAndTruckee » Sat Jun 18, 2011 2:27 am
karsten wrote:The short answer is to delete the unwanted engines from the XML. Does that help? :P
Which XML? They're not in the RRT_Trains_US_East.xml or any other in the US folders, if any of those are what you mean. As far as I can see it, the only way to fix this is to delete them from the trains XML in Custom Assets, which would also delete them from Europe, and thus reducing my playing capacity to America.
vzbob
Post by vzbob » Sat Jun 18, 2011 6:44 am
Use the Modified XML file Snoopy55 posted above BUT rename that to RRT_Trains.xml Save it and then put the renamed file into your My Games\Sid Meier's Railroads!\CustomAssets\XML\_SCENARIOS_\US_East folder.
Then in the same folder open the RRT_Scenario_02_US_NorthEast.xml file and goto the bottom and find the line
<TrainsXMLFile>RRT_Trains_US_East.xml</TrainsXMLFile>
Replace that line with this line
<TrainsXMLFile>RRT_Trains.xml</TrainsXMLFile>
Save that and then try the map .
Post by snoopy55 » Sat Jun 18, 2011 8:36 am
I just ran the file in my system and it did what it had to do, work.
Note to Vzbob and others, unless you are POSITIVE you know the programming of this game, you should NOT edit the original files. This game, like all others run with Windows, uses the file with the newest date if it finds two with the same name.
Now to the problem. Confusion. Mine. I made that change back in Sept of 2007. What I did was resave it to give it a more recent date. While renaming them I got them mixed up and sent you the older one. Try the attached one. Also, do you have any SAMs or other Modded maps loaded? That can cause a problem also.
Vzbob - what you have him doing will cause ALL the maps, US or otherwise, to supply only US engines. The date code will have the game replacing it with the original RRT_Trains.xml. Not good.
Sorry bout the error.
(429 Bytes) Downloaded 434 times
VirginiaAndTruckee
Post by VirginiaAndTruckee » Sat Jun 18, 2011 8:00 pm
Didn't do anything.
VirginiaAndTruckee
Post by VirginiaAndTruckee » Sat Jun 18, 2011 8:08 pm
This didn't help either.
Post by snoopy55 » Sun Jun 19, 2011 1:38 am
Ok, let's try it this way.
First, is this a STEAM version? If so, we will have to get drastic. Go find a shotgun!
First, non STEAM. Go into My Games\Sid Meier's Railroads!\CustomAssets\ and create a new folder, XML. Unzip the file below and place the folder into this folder. Be sure your CustomAssets is empty except for this folder.
Run the US NorthEast map. You SHOULD see the Grasshopper. The rest of the US maps should do the same.
If this is a STEAM version, I hate the idea, but try this..... go into the main game folder and on into Sid Meier's Railroads!\Assets\XML\_SCENARIOS_ and place that folder in there.
If none of this works, I cannot understand why. All the US maps refer to the US East Trians XML and once that is change they will all be showing only US engines.
temp.7z
(5.24 KiB) Downloaded 448 times
VirginiaAndTruckee
Post by VirginiaAndTruckee » Sun Jun 19, 2011 4:33 am
snoopy55 wrote:Ok, let's try it this way.
OK. This worked, but now all the European trains are red blobs with a top speed of 0km/h. I'd rather have Europe and European trains be available to me than only have America.
*EDIT*
I put everything else back into Custom Assets, and it's all back to normal.
*RE-EDIT*
I feel really stupid, All I needed do was delete a second version of the FEF-3 and FEF-3 greyhound and it returned it to normal, while still allowing the trains I've downloaded from here. :shock:
Post by snoopy55 » Sun Jun 19, 2011 9:25 am
Hmmmmm So all this time it has been because of an editing of the Trains XML that was somewhere on your system that we knew nothing about........
Yup, that explains it.
VirginiaAndTruckee
Post by VirginiaAndTruckee » Sun Jun 19, 2011 2:27 pm
snoopy55 wrote:Hmmmmm So all this time it has been because of an editing of the Trains XML that was somewhere on your system that we knew nothing about........
Sadly, yes.
Post by Rodea2007 » Mon Jun 20, 2011 2:17 am
Actually, to use all existing trains (original train) you do not need to do anything, you need to do is when you start the game on windows setup scenario, there is the option "use all trains" on the bottom right so you only need to check the this option then you will be able to use all of the trains that carried by this game. for trains that come as a mod you can use for the above case by including listing the train into RRT_Trains.xml
keotaman
Post by keotaman » Mon Jun 20, 2011 2:51 am
On mine, the "use all trains" option is only available in train table mode, not when playing a scenario.
