4-8-4 Golden State Revision 2
Post by wingsofphoenix » Sun May 23, 2010 1:38 pm
Here is my first modded Train, i want to share.
I thought to start with the GoldenState , because it was already very nice modelled. 8)
The first version is the GS-2 #4412:
New Revision 2
Revision 2: <Update>
  • - Based on GS-4 Rev2 model
    - Changed smokebox door, headlights and cab to match GS-2
    - rescaled and smoothed tender
    - Polygon Count: 6062 (Engine 4831, Tender 1231)
Pictures:
Installation:
Extract the .zip and start the unpacked selfextracting archive from it and follow the instructions of the included ReadMe for XML editing.
I hope you enjoy it, so here it is :mrgreen:
4-8-4_GS-2_daylight_ver2.0.rar
Revision 2
(1.21 MiB) Downloaded 1115 times
Last edited by wingsofphoenix on Sun Dec 12, 2010 10:58 am, edited 11 times in total.
NewYorkCentral
Re: 4-8-4 Golden State Revision
Post by NewYorkCentral » Sat May 29, 2010 9:43 pm
Wow!!!!! I am sooo getting that!!!!
American train fan in SMR!!!!
4-8-4 Golden State GS-4 Revision 2
Post by wingsofphoenix » Sun May 30, 2010 9:57 am
New Revision 2
Second Version:
Golden State GS-4 (SP #4449)
Revision 2: <UPDATE>
  • Complete Engine Model Overhaul:
    - new Boiler
    - new Details (2nd Headlight, a Bell, Firebox, Handrails and more)
    - added Engineer
    - adjusted over 50% parts and details (e.g. overall length, wheel base, wheel diameter)
    - Polygon Count: 7589 (Engine 4924, Tender 2665)
    Tender Changes:
    - added backlight
    - adjusted scale
    Texture Changes:
    - retextured most parts
    - 3 Versions (2x SP Daylight, American Freedom Train)
Installation:
Enjoy
4-8-4_GS-4_Style2_ver2.1.rar
SP Daylight #4449 Style 2 (1941-1955 and since 2003)
(1.35 MiB) Downloaded 677 times
4-8-4_GS-4_Style1_ver2.0.rar
SP Daylight #4449 Style 1 (1980-2000)
(1.35 MiB) Downloaded 651 times
4-8-4_GS-4_AFT_ver2.0.rar
SP #4449 American Freedom Train 1975-1979 and 2001-2002
(1.34 MiB) Downloaded 700 times
Last edited by wingsofphoenix on Fri Jun 17, 2011 2:59 pm, edited 10 times in total.
Post by wingsofphoenix » Sun May 30, 2010 10:14 am
.. and here is the last one of my revision:
New Revision 2
GS-6 (SP #4460)
Update 2.2: <Update>
  • - added the missing Animation files...
    - fixed windows issue
    - added Engineer in XML
Revision 2:
    - scaled down Drive Wheel diameter from 80" to 73,5" (as original)
    - New Rod and Wheel animation because above change
    - Removed skirting
    - Added some details below the new walkways (steam brake cylinders, air compressor, tubes and more)
    - Black painting
    - not 'only passenger and mail' service
    - Polygon Count: 7658 (Engine 4993, Tender 2665)
Pictures:
Installation:
Have Fun
4-8-4_GS-6_ver2.2.rar
Update 2.2
(1.27 MiB) Downloaded 723 times
Last edited by wingsofphoenix on Sat May 28, 2011 8:38 am, edited 8 times in total.
Post by karsten » Mon May 31, 2010 10:48 pm
COOL! Looking forward to the unveiling. :P
Post by wingsofphoenix » Wed Jun 16, 2010 9:32 pm
UPDATE:
I managed to get the Wheel Animations to work, and i uploaded a new version (v2) of all 3 Models! :mrgreen:
Also improved the textures of the GS-2 Tender slightly.
All 3 Tenders now require the 6-axles Tender Animation Update .zip from the first Post!
Enjoy
P.S. Thanks to Rodea, for making the animation for my medium tender and to understand how it works. I used that for this animation, just had to add 2 additional wheels. :mrgreen: :mrgreen:
Last edited by wingsofphoenix on Sun Jun 20, 2010 9:06 am, edited 1 time in total.
Pureon
Post by Pureon » Thu Jun 17, 2010 6:17 pm
These look great!
I haven't downloaded new engines before but once I find out how to make them work in a scenario I'll try them.
NewYorkCentral
Post by NewYorkCentral » Tue Jul 20, 2010 2:16 pm
Don't forget the Daylight.
NewYorkCentral
Post by NewYorkCentral » Fri Aug 20, 2010 7:31 pm
The GS-4 has 2 headlights in the middle of the face.
Post by wingsofphoenix » Sat Aug 21, 2010 10:15 am
NewYorkCentral wrote:The GS-4 has 2 headlights in the middle of the face.
Yep i know that, and the boiler will need a rebuild too, its shape is far from the original. Thats something i will have to change later :mrgreen:
BandOFan
Post by BandOFan » Sun Aug 22, 2010 7:49 pm
If we already have Rodea's 6 axle wheel animations installed do we still need yours from this thread?
Post by wingsofphoenix » Sun Aug 22, 2010 9:38 pm
BandOFan wrote:If we already have Rodea's 6 axle wheel animations installed do we still need yours from this thread?
never thought about that, but i guess you could use them, if you know how to edit the tender .kfm and change the 4 _wheel_layer_wheels_.. animation file names to match rodea's files. :roll: :mrgreen:
Post by Jancsika » Sun Aug 22, 2010 9:56 pm
If and when you have the final version of your engines, (or anything else) please post them in the "Construction Set" thread.
We try to keep them organized, so other people can easier find and use them.
BandOFan
Post by BandOFan » Sun Aug 22, 2010 11:45 pm
In other words, "Yes". :)
Thanks for the info.
Post by wingsofphoenix » Sun Sep 19, 2010 9:58 pm
After adding the tender and some minor changes of the engine, here is now the model rebuild as promised
At first i will start with the
GS-4 (Southern Pacific #4449)
Revision 2 Changes <UPDATE>
    - new Boiler
    - added Engineer
    Tender Changes:
    - added backlight
    - adjusted scale
    Texture Changes:
Last edited by wingsofphoenix on Sun Oct 03, 2010 10:16 pm, edited 1 time in total.
