Looking for help...
Looking for help...
I am trying to edit a passenger car. Where do I find the files that I need to edit? I have a converter but can't find the dds file. Do I need to convert the fpk first? If so what is the recommended program?
Thanks,
E-Time
Thanks,
E-Time
The FPK for the Cars is in C:\Program Files\2K Games\Firaxis Games\Sid Meier's Railroads!\Assets (unless you told it to load elsewhere). Dragon UnPACKer 5 is a good program for this and it's free. For editing the NIF/KFM files, NifSkope works for me.
Just use the UnPACKer to put the files into a folder and edit away. You can use PakBuild.exe to stuff your creation back into a FPK file. The UnPACKer will do this also, but PakBuild is my choice. When you pack it tho, let it place the FPK file in the folder where the files you are packing are. I chose to place it in with the rest of my FPKs and it deleted them out. Nasty...
I've done it with a few cars and Industries, including my recent Cast Iron Car. You just have to watch that when you change names in the Nif and KFMs, that you get all the letters changed. Same goes for the file names. I also tried just leaving the 'steel' in the files that did not seem important, figuring 'the less I change, the less the game has to load as it would be there from the Steel Car'. Didn't work. I had to change the full set. One thing you don't have to play with or include in your resulting FPK is the wheel sets. It has those available elsewhere and does use them.
"stuff your creation back into a FPK file"...translation...to pack or repack into FPK filesnoopy55 wrote: You can use PakBuild.exe to stuff your creation back into a FPK file. The UnPACKer will do this also, but PakBuild is my choice.
PakBuild: http://forums.civfanatics.com/showthread.php?t=136023 and for a bit of info: http://planetcivilization.gamespy.com/V ... etail&id=1
Dragon UnPACKer 5: http://www.softpedia.com/get/Programmin ... CKer.shtml
