Is it possible to route a train via a different part? In other words, if I have two rail paths connecting 2 cities (tracks arent parallel to one another - rather one is longer and more roundabout than the other), is there a way to direct some trains to take the longer route, whilst others take the shorter one? This would help save from congestion.
Is something like this possible? How do I do it?
Thanks
Train Routes
Re: Train Routes
Not really.
You can sort of fake it by restricting the available tracks, but such a solution is nih impractical.
Re: Train Routes
2 ways, SeaTan -- have an extra stop in one path, and use that stop when you setup/change the train's consist (forcing the train to take that path), and a different stop in the other path. The other way to deal with congestion is to use only LH or only RH crossovers between the two paths - that way, trains will be diverted to their own "direction-of-travel" track.SeaTan wrote:... is there a way to direct some trains to take the longer route, whilst others take the shorter one? This would help save from congestion. ...
PM me if you need more.
Btw - your SMR crashes have been fixed now?
Re: Train Routes
Say you have connected two towns A and C. Then as long as there is a resource point B between them, you can set your one train to go ABC. If the other route is A, D, C, with D a different resource point, you can direct trains to take the ADC route. As long as there is no demand for the train goods at C or D, the trains do not lose their cargo.
This way, both trains can start from the same single station track in A and in C, and yet are forced to take different routes.
A refinement of this is the "eye"-shaped track, where about six trains can be forced to circle from A to C north track and back C to A south track, without ever colliding, and using only a single station track in both station A and C.
Uh oh - I see Keotaman beat me with the answer.
