Hi Everyone,
I just discovered this game and I find it quite addicting...
But I'm having a problem with depot connections.
I was reading in this forum that 4 lines can connect to a depot, but I thought I'd read in the manual that only 3 lines can be serviced by a depot?
I started looking because when I added a fourth line into London, I could not stop there, so I continued the line to a further city and I could stop at all the cities on the route except London.
After the first line was laid, the three later lines were added via double tracking.
Is there a trick to getting the fourth connection?
Thanks!
Red
Depot connection problem
Re: Depot connection problem
in the game when you build a depot it only has room for 3 lines the 4th will be become usable when you upgrade the depot to the Terminal. so only make 3 lines to it or upgrade it to the terminal before you add more lines.theCimmerian wrote:Hi Everyone,
Thanks!
Red
Bobby's Sid Meier's Railroads Forums and Bobby's Sid Meier's Railroads Wiki
:: The Only Working & Up to date Wiki Now ::
Thanks bobby.
The hazards of not reading because I'm too busy playing...
