Blezz
Post
by Blezz » Mon Oct 22, 2007 5:59 am
hi, new here sry if i post it on the wrong place
the problem is that my eyes are burning after looking through the forum and i dunno which patch to download first and wer are the links, so if u dun mind, could you tell me?
Post
by atani » Mon Oct 22, 2007 6:24 am
The first place I would suggest is to head over here:
http://smr.atani-software.net/ and download & install the SMRI modpack. This will give you 20 new scenarios and also the basic set of required "mods" for most of the other maps on this site.
Blezz
Post
by Blezz » Mon Oct 22, 2007 8:51 am
nvm i noe wad to download, wads next
Post
by Warll » Mon Oct 22, 2007 2:38 pm
Do you have the patch for SMR from Fraxis?
Blezz
Post
by Blezz » Mon Oct 22, 2007 2:45 pm
yup, both
Post
by Warll » Mon Oct 22, 2007 2:50 pm
Only Fraxis' 1.10 patch is needed since its the newest. But anyway you should now have everything you need so go play SMR!
Blezz
Post
by Blezz » Mon Oct 22, 2007 2:58 pm
right but some how i still keep ctd. anyway to stop it?
Post
by Warll » Mon Oct 22, 2007 3:09 pm
When and where is it CTDing. As well did you install the Santa map form Fraxis?
Blezz
Post
by Blezz » Mon Oct 22, 2007 3:11 pm
after playing for almost half an hour. i'm not sure if its the santa map but its called the holiday scenario and its from gamespot
Post
by atani » Mon Oct 22, 2007 3:30 pm
Blezz wrote:after playing for almost half an hour. i'm not sure if its the santa map but its called the holiday scenario and its from gamespot
Uninstall SMRI, remove all directories under My Documents\My Games\Railroads (name may be different, depends on your installation). Then reinstall SMRI.
SMRI includes the Holiday (santa) scenario from Firaxis.
The problem you are likely encountering is related to the installation order of the addons. Installing the Holiday scenario from Firaxis (or otherwise) will cause problems with custom maps due to how the game works with regard to the CustomAssets tree.
Blezz
Post
by Blezz » Tue Oct 23, 2007 10:11 am
hey i used add or remove program thing to remove the holiday scenario i downloaded form gamespot and SMRI and the patches and reinstall SMRI and the patches again. but it still CTD and it keeps being not responding.
Post
by atani » Tue Oct 23, 2007 2:55 pm
Blezz wrote:hey i used add or remove program thing to remove the holiday scenario i downloaded form gamespot and SMRI and the patches and reinstall SMRI and the patches again. but it still CTD and it keeps being not responding.
After removing things via Add/Remove programs you must go in and remove any left overs. Some uninstalls are really bad about leaving some pieces behind. SMRI does attempt to cleanup after itself but some pieces are a little harder to clean out than others...
Blezz
Post
by Blezz » Tue Oct 23, 2007 2:57 pm
sry but i dunno how to do that haha
Post
by atani » Tue Oct 23, 2007 3:07 pm
Blezz wrote:sry but i dunno how to do that haha
From my post a few above:
Except instead of just uninstalling SMRI, uninstall any additional mods you may have applied and then remove all other files in the directory referenced above.
