Can't delete a terminal?
Hi folks!
I want to totally reconfigure a town's Terminal by deleting it.
The game won't let me, even if I delete all the track connecting to it, and all trains associated with it.
It's funny because earlier in the game, I kept accidentally deleting this Terminal when finessing some track.
If it matters, this is the Germany scenario, and it's my starting terminal.
Any ideas? I tried the Map Editor, but it doesn't seem to load/edit savegames per se, it must be only for (underlying) maps.
Thanks if you can help! - RK
RedKnight wrote:Right Kro, but it won't let me do that. The last bit of track gives a "doink" sound and won't let me delete it or the terminal.
It is not the only track on the map, of course. Maybe somehow it thinks it is??
Try extending the track just a little. And click on the terminal sectoin of the track and delete. If the game really thought that was the last track, then this should fix it.
Terminal
Recently I played a multiplayer game where one player did nothing. After awhile he left the game. The AI took over and did nothing as well. All it had was the orginal terminal and starter track, nothing else. I bought the AI out and was able to connect my track to the former AI track, but I couldn't run a train to that station, it wouldn't show up as a destination when trying to set new route. But I also couldn't add a station there as it would tell me one already existed.
I really hope if there is another patch they fix alot of these issues. Especially the stock issues. It's just crap being bought out when you own all shares in your company and you end up with nothing.
- darthdroid
Never seen this, here are possible solutions:
First, if there are double tracks, you must delete outside tracks first.
Second, can't delete track with train on it.
Third,...maybe you cant delete the last piece of track, so build a tiny piece off your station track.....one which will exist when (hypothetically) you delete the station track, try that. I delete starting terminals frequently and never had this problem.
-Bob the Lunatic
-Bob the Lunatic
- Slappy Da Clown
Terminal
Hi All
Just some random thoughts from a drunken old clown.
Are you trying to delete the station that the game starts for you ?
If so do you have track & stations in other places already ?
It may be that you cannot delete that station until you have track & stations somewhere else.
Dell Dimension 8400
3GB Memory
Dell Dimension 8400
3GB Memory
- darthdroid
Re: Can't delete a terminal?
Think I figured out your problem Red, this should solve it:RedKnight wrote:Hi folks!
First, ya, you can definitely delete your last station BUT I just checked and you CANNOT delete your last piece of track. So, just take a little single track off the starting track and lay it (like 2k worth should be fine) then delete the starting track and it and the station should delete. All you should have left is the tiny piece you added... I do this all the time, guess I just took it for granted as I never WANTED to delete the last piece of track as I figured I'd be screwed.
One other piece of advice: I remember having this problem early on and finally figured out the problem at some point: When you DO wanna delete a station or depot or whatever, you don't highlight the station. Instead you highlight the adjacent track and delete that, if it's the only piece attached to that station, the station will delete with it.
But I'm 99% sure that the first paragraph will solve your undeletable terminal problem, let me know if not and I'll plug away some more
-Bob the Lunatic
