2 Steam engine request's
sgthellsing
Post by sgthellsing » Wed Apr 06, 2016 9:44 pm
I have a engine request um. i know nothing about making mods or anything like that. but if any one still makes mods could some one try to make this 2 trains here.
If any one can make tho's 2 please let me know.
Re: 2 Steam engine request's
Post by Rodea2007 » Wed Jul 13, 2016 4:46 am
sgthellsing wrote:I have a engine request um. i know nothing about making mods or anything like that. but if any one still makes mods could some one try to make this 2 trains here.
if you can get pictures from those engine ( front, left side, right side, back and top view ) maybe I can build that engine
sgthellsing
Post by sgthellsing » Fri Sep 16, 2016 2:00 am
The attachment a5Shifter.jpg is no longer available
The attachment PRRS2.png is no longer available
Yes i can do that. the PRR S2 will be a little tricky due to that is a rare locomotive to find but the PRR A5 easy i got some pictures i found today. i will post them.
80 a5Shifter.jpg (19.01 KiB) Viewed 17700 times
190 prr677.jpg (111.86 KiB) Viewed 17700 times
191 prr94.jpg (139.74 KiB) Viewed 17700 times
192 PRR A5.jpg (217.08 KiB) Viewed 17700 times
I know some of the pictures are big. i could not find any that where small enough but hope the big pictures can be loaded in to another page for you to see them. hope this helps with the making of the PRR A5 switcher engine. this little engines where strong but from what people told me they only had a 4 to 5 car limit on them. i do not know tho the wiki that talk's about them does not tell how much they could pull. but if you need the stats here they are right from the wiki its self.
Type and origin
Power type Steam
Builder Juniata Shops
Build date 1916–1924
Total produced 47
Specifications
Configuration 0-4-0
Gauge 1,435 mm (4 ft 8 1⁄2 in)
Driver dia. 50 inches (1,300 mm)
Loco weight 131,750 pounds (59,760 kg)
Firebox:
• Firegrate area 38.3 square feet (3.56 m2)
Boiler pressure 185 pounds (84 kg)
Cylinder size 20 inches (510 mm) × 24 inches
(610 mm)
Performance figures
Tractive effort 30,190 pounds (13,690 kg)
Hope this also helps.
