Hi there.....new on this forum and I'm so happy I found this. Downloaded already several maps but this Basin-Map is just the best......
Now, I have a problem. I can start a game, play it, but I can't load it again after I saved it. The other maps all work good, the Basin Map also, but I just can't laod it again....
I have extracted the three main files to a folder and then installed it....
Can someone help please.....thanx.
elcapitan
CRASH Basin & Range
Re: CRASH Basin & Range
The Basin-Map is special. What has helped others is to start a fresh Basin-Map game, and then load your save game from there. Try it and please let us know if that works for you.
HI, thanx for the replay. You mean start the game from the SAVE Folder....directaly from the Basin&Range Game?
Didn't work.....
Didn't work.....
- K-class
Hello as karsten said, just start a new basin and range game and after a few minutes playing this new game just go to the menu and open you saved game.
This helps as loads a lot of the map requirmments into memory.
I had the same trouble with Florida Gold...it is larger and has more content than Basin and Range. I found my save game trouble to be an error in game content. I fixed mine and the save game trouble went away. I believe the trouble is an error in the maps xml's or game content files that is causing this saved game trouble.
It works, thanx a lot guys....
