cant lay track
lil_wilde
cant lay track
Post by lil_wilde » Sun Jan 20, 2008 6:51 am
I know all the reasons I can't lay track, at least the reasons that are explained in the instructions and tutorial. However I cant seem to figure out why I cant lay track. I have the money and I cant even lay a tiny straight piece of track. I don't understand what the problem could be.
Any ideas?
Bushdoctor
Post by Bushdoctor » Sun Jan 20, 2008 10:39 am
Hi Lil_Wilde,
Welcome to the game and forum.
When I started playing the game for the very first time, I wasn't aware
that you can only lay track if it's attached to existing track. For a short
while I was under the impression that I couldn't find the right option to do that.
Perhaps you overlooked the same thing.
(Then again, I didn't read anything but dove straight into the action).
Greets,
Doc.
lil_wilde
Post by lil_wilde » Sun Jan 20, 2008 11:03 am
Hey, thanks for your reply.
I knew that I had to attach it to existing track. I read the instructions and did the tutorial. The problem was that I ddint have the money to lay the track. I thought I did but I was looking at my net worth, not the money I had.
Still, I can't get trains to run a route back and forth nicely. Some will some wont. Some deliver and then stay stuck, costing money. I have to scrap the train and start a new one.
All in all, Im very disappointed with the game. I LOVE Civilization and I expected to have a great game but it's just ridiculous trying to learn how to play it.
Bushdoctor
Post by Bushdoctor » Sun Jan 20, 2008 1:25 pm
Good thing that you found out about the money/networth.
The same thing will probably happen to your routing issues.
You'll find out what you did wrong and correct it.
Keep in mind this is not the last issue that you will run into.
There's other stuff that you want the game to do, but it won't.
It gets worse when the game does stuff you don't want it to. ;)
Still, I think it's a very enjoyable game.
It doesn't compare to tight controlled games like Locomotion
or maybe even Civ, but it has its own charm.
I'm tempted to suggest you should give it another chance,
but I know that won't be necessary. Once you got things under
control you won't be able to put the game down. ;)
Tijer
Post by Tijer » Sun Jan 20, 2008 2:34 pm
Yes it is an addiction and this the location of Railroaders Anonymous. Meeting are held on a continuous bases. We work hard to find new ways to distract ourselves, but we have become addicted to the game and the punishment that it provides. The more the merrier. Welcome.
2 GB PC5400 DDR2 Ram
MB nVidia nForce 680i LT SLI
GC GeForce 7300GS 256MB PCI-E
HD 250GB + 500GB
OS Windows XP/SP2/32 bit
lil_wilde
Post by lil_wilde » Fri Jan 25, 2008 9:18 pm
I did attempt to play it again and found that the trains would make one delivery then get stuck but not always. I connected 2 towns to bring passengers and mail and the train was runnig fine. Then I attached more track to bring ore to the city that makes gold but the train I placed there would make one trip and not keep going.
I wish the instructions were more explicit.
Post by karsten » Fri Jan 25, 2008 9:31 pm
:D
:P Hear, hear! Well put!
sjekazoo
Post by sjekazoo » Fri Jan 25, 2008 11:00 pm
Hey,
I have posted this same thing on a couple of other related threads, but I´ll repeat it briefly here.
I had the same problem and found I could fix it by switching the game to windowed mode and then back to full screen (without closing the options window). If you prefer windowed mode, just toggle to full screen and back again. The minute I close the options window I hear the caching of the stuck loco dropping its load.
Skeeter
lil_wilde
Post by lil_wilde » Sat Jan 26, 2008 7:34 pm
Wow, thats the solution?
Thanks for the help but how is anyone supposed to figure out a glitch like that.
Is this game full of that kind of stuff?
Do the patches fix any of it?
sjekazoo
alt enter
Post by sjekazoo » Sat Jan 26, 2008 8:19 pm
Hey,
Just found out the short cut for switching modes is {alt enter}. It apparently is a problem only encountered by a few users, so there is likely some incompatibility on our systems that causes it. Most lock-ups, crashes and glitches (likely mini-crashes) are caused by errors reading memory, which will happen a lot when your computer resorts to using the hard drive for extra ram. I think this game is an absolute memory hog.
Did you happen to look at the read-me file? It has new minimum-system-requirements that basically say my computer should not even be able to run the thing, so I figure one simple little screen swap is not so bad.
Lots of luck,
Skeeter
Post by snoopy55 » Sat Jan 26, 2008 8:19 pm
lil_wilde wrote:I did attempt to play it again and found that the trains would make one delivery then get stuck but not always. I connected 2 towns to bring passengers and mail and the train was runnig fine. Then I attached more track to bring ore to the city that makes gold but the train I placed there would make one trip and not keep going.
It could be that the Ore train was waiting for a signal. When you lay a track for the Ore, do a double track at the town, then run your rail from the one you just layed. If you don't want two tracks there, you can also start a track a short way from the station and then delete it. This will put a signal tower there and the train can go as far as that and wait for a clear station.
