Holiday Scenario and German RailRaod Version, problem
Gamet
Post by Gamet » Fri Jul 27, 2007 1:54 pm
Hello,
If I install the Holiday Scenario on German version than
no city have a name, why?
Text for mission is in english but no city names showed.
Have V1.1.0.0
Re: Holiday Scenario and German RailRaod Version, problem
Post by atani » Fri Jul 27, 2007 3:59 pm
Gamet wrote:Hello,
Have V1.1.0.0
Where did you get the install for the Holiday Scenario from? Was it the one from Firaxis' website or the one I packaged and posted to this forum?
The simple fix is to go to your CustomAssets folder and find the Names_ENU.xml file to Names_DEU.xml. This will fix the missing city names, but will also unfortunately replace all city names in the game with english names. If you installed via the installer from this forum, let me know and I will check that it is doing the names correctly.
Gamet
Post by Gamet » Fri Jul 27, 2007 4:06 pm
Hello,
I get this file from firaxis homepage.
Your installer of holidays scenario I have do not tested.
Post by Warll » Fri Jul 27, 2007 5:48 pm
Gamet wrote:Hello,
Either way you should be using Atani's version since Fraxis's does not like the Globels.
Post by atani » Fri Jul 27, 2007 6:06 pm
Gamet wrote:Hello,
I would suggest to uninstall it via the normal uninstaller (provided by Firaxis' installer) and then clean up your CustomAssets folder and then install via the installer found on this forum or the Wiki.
