New Train EMD SD40-2 SOOLINE
Post by Rodea2007 » Sat Jun 04, 2011 3:16 pm
Here it is a New Train from EMD with type SD 40-2 SD 40-2 and SD 4-2B
How to install this train?
In the zip file you downloaded is available several types of files:
- SOO_SD40_2.KFM
- SOO_SD40_2.NIF
- SOO_SD40_2.Dummies.nif
- SOO_SD40_2B.KFM
- SOO_SD40_2B.NIF
- SOO_SDA.DDS
- SOO_SDB.DDS
- SOO_SDB_EMSK.DDS
- SOO_SDB_NRML.DDS
- SOO_SDB_SPEC.DDS
- Event_newtrain_SOO_6623.dds
- Routing_SD40-2_SOO6623.tga
and 3 xml files:
- Train.xml
- TrainCars.xml
- Names.xml
Download the zip file and extract into CustomAssets
Then....
Open the file RRT_Trains_xxx.xml
Enter all the listings that exist on the file Train.xml
Next step...
Open RRT_TrainCars_xxx.xml
input all the listings are there on the line below <RRTTenderCars> TrainCars.xml
The final step ... open RRT_Names_xxx.xml
do the steps as above to enter your new train name into the game
Now you've got a new train that can be played
Please enjoy the new train from Rodea2007
EDIT///
Also you need to dowload the both files and put in CustomAssets Folder
1. http://www.smrsimple.com/forums/downloa ... hp?id=4863
2. http://www.smrsimple.com/forums/downloa ... hp?id=4858
EMD SD40-2 SOOLINE.zip
(1.67 MiB) Downloaded 1243 times
Re: New Train EMD SD40-2 SOOLINE
Post by Rodea2007 » Sat Jun 04, 2011 4:07 pm
If you download and use this engine, so left your feedback here...
Post by karsten » Sun Jun 05, 2011 7:06 am
Good stuff - I may be able to use your EMD in my "Rhodes Unfinished" scenario end stage, here are some screenshots. :D I encountered some missing files, however.
Post by Rodea2007 » Mon Jun 06, 2011 2:57 am
karsten wrote:Good stuff - I may be able to use your EMD in my "Rhodes Unfinished" scenario end stage, here are some screenshots. :D I encountered some missing files, however.
Nice Screen Shoots Karsten.... :wink:
talk about some missing files, you can get them on Map Component Train by Rodea in Construction Thread http://www.smrsimple.com/forums/downloa ... hp?id=4863
if you use rodea diesel train 6 axles then you need download this file below:
enjoy with your new Train..... :D
Post by karsten » Mon Jun 06, 2011 11:19 am
Those rodea diesel train 6 axles worked. :D
Why don't you include them in the Soo engine package?
Post by Rodea2007 » Tue Jun 07, 2011 3:52 am
karsten wrote:Those rodea diesel train 6 axles worked. :D
Good Idea Karsten, maybe for the next new machine..... :D
BigBoy4967
Post by BigBoy4967 » Tue Jan 17, 2012 12:47 am
HI Rodea2007 I have been trying to make the train appear in the game but every time I do it, its never in there. I have done everything correct but its still not letting me do it, i even added the two files that you were supposed to add in. Could you please help me solve this problem. :( :?
Post by Rodea2007 » Tue Jan 17, 2012 4:43 pm
BigBoy4967 wrote:HI Rodea2007 I have been trying to make the train appear in the game but every time I do it, its never in there. I have done everything correct but its still not letting me do it, i even added the two files that you were supposed to add in. Could you please help me solve this problem. :( :?
Hi Bigboy4967....I don't what happen to you, should be if you read and follow the instruction it won't happen, send to me the RRT_Trains_yourmap.xml included SOO files, I will check them and give you solve it...
BigBoy4967
Post by BigBoy4967 » Sat Jan 28, 2012 5:04 am
Never mind Rodea I got it fixed i forgot to copy the things for train tag name, but if i were you i would create and installer like choobaca did for his ac4400 warbonnet. Due to the face that some people dont understand where your coming from. :o :idea:
ruthlessdj
Post by ruthlessdj » Thu May 24, 2012 2:11 am
this is my first custom train download so i hope u can help. there seems to be no RRT_Names_xxx.xml file? what should i do? i have ver 1.10
Post by Rodea2007 » Mon Jul 02, 2012 2:59 pm
ruthlessdj wrote:this is my first custom train download so i hope u can help. there seems to be no RRT_Names_xxx.xml file? what should i do? i have ver 1.10
try to upgrade your RRT to version 1.1.0.0
Post by snoopy55 » Wed Jul 04, 2012 7:56 am
If you are putting it into a custom map, it will be in the maps folder. If you plan on adding it to the games original maps, look in (what ever drive you have it in):\Sid Meier's Railroads!\Assets\Localization. There will be 6 of them, one for each of the 6 languages the game was written for.
laloha
Post by laloha » Fri Jul 06, 2012 3:55 pm
Hi all,
This is my first post and could not find a better one to test out my new Member log in.
It works so its a big thanks to, Daniel Dressler, for clearing my membership.
I did pick up most of the new layouts made available here and must say I missed a lot sitting of in a pile of mushrooms over the last couple of years. Was besides myself finding this site, and seeing all the progress in SMR. Most outstanding.
Hope to follow up on this thread when return the week of the 16th July. Off for now to be with family of a dear friend we lost to a better place, recently. Will be missed by many.
So, again thanks to all, see later,
Larry
Post by Rodea2007 » Sat Jul 28, 2012 5:01 pm
BigBoy4967 wrote:Due to the face that some people dont understand where your coming from. :o :idea:
I'm so sorry to late to reply your question...
I come from Indonesia, an archipelagic country located in Asia Southeast Asia rather
